TV lighting socket/plugs - Fiberglass RV
Old 12-09-2016, 07:25 AM   #1
Name: Billy Sharpstick
Trailer: Scamp 13 - 2005
I want to replace that wimpy rubber 4-way plug that is hanging below my bumper to a good round socket.
I found a combination bracket with a 4-way socket and a 7 pole vblade socket at https://www.etrailer.com/Wiring/Curt/C57674.html
This still lets me plug in my old utility trailer or illuminated receiver step.
The blade looks more solid than the round version. Seven is better than 6 or 4, and I can add electric brakes etc. later.
Any suggestions on the best way to wire lighting?
sharpstick is offline   Reply With Quote
Old 12-09-2016, 11:43 AM   #2
Depends on what "lighting" you are referring to. Are you talking about interior trailer lighting, as like reading lights, or are you talking about wiring up running lights?
If you are needing a standard wiring diagram for the 7-Pin connector, then here is one.
Old 12-09-2016, 12:35 PM   #3
Running lights. My old connector is the common flat 4 wire plug. I want to replace it with a more robust round one. (I don't know why interior lights would be connected to the TV(towing vehicle).
Old 12-12-2016, 07:49 AM   #4
Pins vs blades
So, it's down to 7 way pins vs blades. The blade versions look more sturdy.
Old 12-12-2016, 08:01 AM   #5
You don't have to have a separate 4-way plug. You can buy an inexpensive adaptor. Mine lives in the storage cubby in the back of my TV so I can always find it when I need to hook up the utility trailer.
Old 12-12-2016, 09:24 AM   #6
librarianocnj's Avatar
Trailer: Casita Independence "Callimachusita"
Ocean City, NJ
If you are lucky enough to find these in stock at a local Kmart, they are only $7.
http://m.kmart.com/hopkins-multi-tow...W302851110001P
Gordon and Anne
2010 Suzuki Equator "Suzi Q"
2015 Casita Independence "Callimachusita"
Pod Puppies: Josie and Frankie, Casita Kittens: Madison & Razzel & Mrs. Chow
librarianocnj is offline   Reply With Quote
Old 12-12-2016, 10:39 AM   #7
The only problem here is that you will still need to wire that unit up for use as a fully functioning 7-Pin connector, or else why bother at all if you're only using the "flat four" connector part, which you already have? If you want all 7 pins hooked up, which BTW will also give you 12 VDC for your interior loads, (also including battery charging and trailer interior lighting,) then you are in for a little bit of wiring under the tow vehicle to make it fully usable. The four flat connector merely taps into the Stop/Turn/Running lights. The 7-Pin gives you more circuits, such as ones you would need to power things like electric brakes, a battery charging circuit, (fed from the tow vehicle,) reverse lights, etc. It's all dependent on your trailers needs. If it's just a utility trailer to go to the dump with, then a 4-Pin is all you need. If you have a travel trailer, then you'll need the larger connector to accommodate all the other trailer electrical loads. Also, depending on your tow vehicle, especially with many European and Asian models, you may also need to add a lighting wire converter to make your lights work properly.
And FWIW, I wouldn't buy one of those K-Mart cheapo units because they aren't made very well, and the wiring they use is generally smaller as well. You get what you pay for. Buy a brand name.
Old 12-12-2016, 11:17 AM   #8
Yes, I will add wiring for future brakes, battery charging, possibly reverse light. That's why I'm going with the 7 way system. And yes, I do have a utility trailer for dump runs. That's why I want both plugs. And yes, I do have a travel trailer(hint: That's why I'm on this forum) My existing 4 wire socket works, so hopefully no rewiring will be necessary.
light, lighting
Covering the backside of a 12v socket deryk Modifications, Alterations and Updates 7 12-24-2013 07:54 PM
Does anyone know where I can get replacement plugs for my Scamp hot water heater? SharonM Problem Solving | Owners Helping Owners 16 11-03-2013 11:41 AM
need advice troubleshooting ciggy lighter socket in Burro rabbit Problem Solving | Owners Helping Owners 26 03-24-2012 07:10 PM
Frustration with cheap 12v plugs... Al Stansell Problem Solving | Owners Helping Owners 6 06-01-2007 05:52 PM
Broken light socket - Trillium Robert St.Louis Problem Solving | Owners Helping Owners 5 09-27-2006 04:11 PM
