U-Haul CT-13 Project - Detroit - Page 4 - Fiberglass RV
Old 07-20-2016, 07:32 AM   #43
cjwebber's Avatar
Trailer: U-Haul CT-13
Been progressing nicely!
  • Installed LED Clearance lights
  • Installed Brake/Turn LED bar above rear window
  • Pulled majority of 12v wiring (lights and fan)
  • Cut out and mounted PD-4045
  • Wired and Tested Fantastic Fan (WE HAVE POWER!)
Waiting for more supplies to arrive:
  • LED Light Fixtures
  • Solar Mounting Kit
  • Bogart Trimetric SC-2030 & TC-2030 (Solar Charger + Battery Monitor)
  • Terminal Blocks for 12v Wiring + Cable Management
Will spend the next day or two working on some more fiberglass repair while I wait for more parts to arrive.
cjwebber is offline   Reply With Quote
Old 07-20-2016, 07:50 AM   #44
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Christopher, thank you again for sharing all your hard work with us. I like the location of the PD-4045 because you can get to it if needed and you are using otherwise wasted space. Good job.
D Davis is offline   Reply With Quote
Old 07-20-2016, 08:13 AM   #45
cjwebber's Avatar
Thanks! I left a bit of space so I can install the Trimetric 2030 Battery monitor in the old battery monitor space, as well as propane line access for my furnace. Its really astonishing how much space is there!
Old 07-21-2016, 04:02 PM   #46
cjwebber's Avatar
Testing out the dimmer switch and placement for the recessed LEDs.
Screen Shot 2016-07-21 at 6.01.57 PM.png   Screen Shot 2016-07-21 at 6.01.39 PM.png
Old 07-23-2016, 06:39 AM   #47
cjwebber's Avatar
Yesterdays accomplishments:
-Created 12V Junction Panel to terminate all 12V accessories
-Installed recessed LED fixtures
-Installed dimmer switch for cabin lighting
-Installed LED fixture over closet
-Installed LED fixture above sink
Waiting for Solar Charger and Battery monitor - then I will tackle solar!
Old 07-31-2016, 11:13 AM   #48
Beautiful job on the wiring, it is looking very good.
But add a few tie wraps. One goes within a few inches of the start or ending of a bundle of wires, and then every 6 inches or so inches along the length of the bundle and also at any break outs from the bundle that go off to the different fixtures.
Sorry can't help it, I used to work at Boeing creating wire bundles and also worked inside the planes with them and had to know how these things are done. The tie wraps help reduce the strain on the individual wires and prevent accidental snagging of loose wires. Rubber nails are used to fill in any slack inside of P clamps so that the wires can't be pulled around in them. A piece of rubber screen spline can be used or some such soft object that fills up the space so there is no movement within the P clamp.
Old 07-31-2016, 11:36 AM   #49
cjwebber's Avatar
Thanks - And also, Great suggestions!
I'll be doing some wire-ties and also some of this stuff:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Gonna wait til I'm pretty sure I've got all the wire runs that I want!
Old 08-05-2016, 03:33 PM   #50
Trailer: U Hall VT
Wonderful, very nice job!
Roger Kimble is offline   Reply With Quote
Old 09-05-2016, 08:00 PM   #51
l.hoskins's Avatar
Trailer: Uhaul
I wire brushed the frame... no holes were found so no welding necessary. Then I used POR15 and Black gloss rustoleum and brushed it on (2 coats) It has been 3 years and looks great.
For the carriage bolt replacements I didn't use rubber washers but instead used metal ones to distribute the pressure evenly. If you noticed the beautiful hour glass shape the old ones took on after rattling around in those holes.
l.hoskins is offline   Reply With Quote
u-haul
Hello from Detroit! New U-Haul CT-13 Owner! cjwebber Hi, I am.... 2 09-05-2016 07:52 PM
83 Casita CL Detroit - $2300 Lora Referrals: Molded Fiberglass Trailers 1 02-04-2013 05:00 PM
Looking for a Destination within 4 hours South of Detroit Thomas G. Camping, Campout Reports 16 10-07-2012 02:40 PM
Detroit: Amerigo $500 Peter_Crowl Referrals: Molded Fiberglass Trailers 15 02-18-2011 06:57 PM
SOLD - 1982 Scamp 13', Detroit CL Pat B Ohio Classified Archives 1 08-11-2008 06:59 AM
