U-Haul restomod - Page 3 - Fiberglass RV
Old 11-06-2012, 11:03 AM   #41
Trailer: U-Haul CT
OK. I guess rational reasoning and practical thought (yours) have overridden gut level emotional reaction. I will be patching the hole and soft spots and not trying to replace the entire floor. The attached photo shows the first replacement in place. It will get another coat and the underside will also get fibergalssed. The soft section in the rear will get a similar treatment. I am thinking I will then put down a layer of underlayment to level out the floor prior to laying down a new vinyl floor.
EXCS_CT is offline   Reply With Quote
Old 11-06-2012, 11:06 AM   #42
Trailer: U-Haul CT
Oh yes, the Grill was a fooler, Mr. Steve, because it is totally hand built.
Old 11-06-2012, 11:07 AM   #43
Trailer: U-Haul ct-13
Quebec
Dave
I have stripmy down all the way so if you have any question just send me a mp and will do my best to help you out !
Fred
theman is offline   Reply With Quote
Old 11-06-2012, 12:12 PM   #44
Thomas G.'s Avatar
Nice work and QUICK!. At the risk of pointing out the obvious, all that protects the plywood from rot is the fiberglass coating. When ever I put a hole in my floor, I drill the hole oversize, tape the bottom, fill with resin, let it cure, then drill the hole size I need in the resin. The result is a sealed floor. The vents I used were about 3/4" in diameter.
Here is what I used for a drain in my floor.
Old 11-06-2012, 03:21 PM   #45
Steve_N_Janna's Avatar
Name: Steve and Janna
Trailer: '02 Scamp 13
Smart !!!
I am copying that idea.
Steve_N_Janna is offline   Reply With Quote
Old 11-11-2012, 05:04 PM   #46
Trailer: U-Haul CT
Well, I was finally able to get back to my shop to work on our CT floor. I cut out the soft section in the rear and replaced it with new plywood. It was in a difficult location to ct it out. So, I used my angle grinder with a cut off wheel. It worked fine until I got to the solid wood. It was evident when I hit good wood because I got a great deal of smoke. It may be hard to see but I attached a picture to show a bit of the smoke.
Old 11-11-2012, 06:51 PM   #47
Thomas G.'s Avatar
Great! Sure beats doing a whole floor replacement. How many other bad spots are there?
Old 11-11-2012, 07:21 PM   #48
Trailer: U-Haul CT
I think only one more. I may be able to tackle it tomorrow. Then maybe I can get to filling some holes left over from removing the furnace, etc.
Old 11-16-2012, 06:16 PM   #49
Trailer: U-Haul CT
final floor patch
I finally got back to the shop today. I repaired the last floor problem (I hope). I do still need to get under the CT to coat the patches with resin. I removed the hitch, cleaned it and painted it. I also got around to removing the rear bumper to make it easier to get to the rear of the camper in preparation for paint.
Old 11-17-2012, 08:28 PM   #50
Trailer: U-Haul CT
The gas line is now out. We don't intend to use gas for cooking or heat. I got some of the frame cleaned and painted. The wood seat boards are now coated with urethane. They will get and additional coat tomorrow, I hope. Oh, yes I also worked on the the shell filling small holes and cleaning the surface. There's still a lot of it to go though.
u-haul
U Haul CT 13 h.mike Problem Solving | Owners Helping Owners 4 10-26-2011 07:50 AM
U Haul Greg H General Chat 1 01-20-2011 06:46 PM
85 U-Haul Greg H Referrals: Molded Fiberglass Trailers 5 01-12-2011 03:41 PM
U-haul Value? Chet F General Chat 2 04-24-2007 06:00 PM
Old U-Haul John Perry Problem Solving | Owners Helping Owners 7 10-01-2006 05:15 PM
