UHaul CT 13 TV Wiring - Fiberglass RV
Old 12-03-2011, 01:50 PM   #1
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
My CT13 has a 4 pin connector to the TV. It occurs to me that I should at least add an additional connection so the the deep cycle battery is charged from the TV while I am underway.
I could convert both vehicles to a 7 pin connector, or just add an additional weather proof plug. Would the connection at the trailer just be made to the + terminal of the battery or is there a need for a diode as well as a fuse? A diode would prevent accidental back feeding to the TV from the inverter.
Comments / suggestions?
Old 12-03-2011, 06:54 PM   #2
honda03842's Avatar
Name: Norm and Ginny
Switch
To prevent charging or discharging in either direction, I installed a lighted switch on the dash of the tow vehicle in line from the battery to the trailer. As well I have a 15 amp fuse in the line.
I only charge when underway and shut it off before I stop. As a double check I always disconnect electrically from the tow vehicle even if I am not mechanically disconnecting from the tow vehicle.
A number of people on the site have installed a relay to perform this function. I like doing it myself.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 12-04-2011, 11:20 AM   #3
Thomas G.'s Avatar
Thanks for the reply. Any thoughts re the wiring connector? If I change it to a 7 pin it will be standardized, though just adding a second connector would be easier for me.
Old 12-04-2011, 01:59 PM   #4
Trailer: U Hall VT
You would like it better if you changed to a RV 7 plug, then it would be done.
Roger Kimble is offline   Reply With Quote
Old 12-04-2011, 02:15 PM   #5
You need a heavier gauge wire for the TV to Egg battery charging so it would be best to go to the 7 Plug/Jack as Roger recommended above then wire both vehicles with the proper gauge wires. Do it once, do it right and forgetaboutit.
Old 12-04-2011, 05:54 PM   #6
Trailer: Fiber Stream
I recommend converting to the 7 pin system also, just to keep it standardized and simple to use.
uhaul
Wiring Solar Bigfoot Mike Problem Solving | Owners Helping Owners 4 08-16-2009 10:33 AM
RV Wiring Darwin Maring Problem Solving | Owners Helping Owners 8 01-27-2007 03:45 PM
Wiring questions Paddy Morris Problem Solving | Owners Helping Owners 4 04-26-2006 03:28 PM
Invisable Wiring Con Problem Solving | Owners Helping Owners 12 04-16-2006 07:44 PM
Wiring Questions, etc. Legacy Posts Problem Solving | Owners Helping Owners 6 06-03-2003 10:43 AM
