UHaul CT13 Undersink Cabinet w/ Shelves - Fiberglass RV
Old 01-07-2012, 10:15 AM   #1
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
MY CT13 didn't come with a cabinet liner and I found the under sink area to be ugly and inefficient. I decided to make my own liner with shelves that would be easily removable so I can access the hoses and connections that live in that area.
Old 01-07-2012, 10:18 AM   #2
Thomas G.'s Avatar
I looked around for some kind of a ready made insert and found this Itso modular cube at Target - just the right size and it comes with various shelves and insert drawers.
Old 01-07-2012, 10:24 AM   #3
Thomas G.'s Avatar
Just one problem - there is interference with the wheel well in the back left corner, so I needed to trim off the corner. But how to do it so it didn't look like a hack job? I made a duplicate cube from cardboard, cut the corner off roughly, then added back the needed contour with cardboard scraps and duct tape. Once I had the exact right shape, I transferred the cut to the plastic cube.
Old 01-07-2012, 10:29 AM   #4
Shirley LaMoine's Avatar
Trailer: '82 13' Burro
Nice idea! I have the same problem with my Burro. Could you post a picture of how the cube looks installed?
Shirley
Shirley LaMoine is offline   Reply With Quote
Old 01-07-2012, 10:33 AM   #5
Thomas G.'s Avatar
Next I needed to mount the cabinet so it would be easily removable. I attached an aluminum carpet trim corner to the front edge of the cube with small pieces of wood to capture the cabinet lip. The rear left side sits on the wheelwell, but the right side needed support. I added a short length of plastic pipe to support that corner. Using a hole saw, I cut a wooden disc the diameter of the inside of the pipe, inserted it in the pipe, secured it with screws and screwed the pipe to the corner from inside the cube.
I also added some extra window flocking to the corner to trim it out.
Old 01-07-2012, 10:36 AM   #6
Thomas G.'s Avatar
Finally, I got some edge trim from JC Whitney, and ran it around the raw fiberglass edge of the cabinet. In the latch area, I trimmed off the back so the latch still works. Due to the wheel well, I had to shorten the left drawer. I cut it with a utility knife and "welded" it back together with a soldering gun.
Old 01-07-2012, 10:37 AM   #7
Thomas G.'s Avatar
Final product vs old.
Old 01-07-2012, 10:39 AM   #8
CindyL's Avatar
Illinois
Nice!
CindyL
CindyL is offline   Reply With Quote
Old 01-07-2012, 11:05 AM   #9
melissab's Avatar
Trailer: 2012 Scamp 13 DLX
Amazingly Clever! I wouldnt have begun (began?) to know how to tackle such a problem.
Melissa in Florida
2016 Honda Odyssey
melissab is offline   Reply With Quote
Old 01-07-2012, 11:38 AM   #10
Sweeeet!
Old 01-07-2012, 01:01 PM   #11
Thomas G.'s Avatar
Thanks for the kind words. We shall see how it works out - may need a little finessing.
Old 01-07-2012, 02:05 PM   #12
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
kirkman is offline   Reply With Quote
Old 01-07-2012, 02:21 PM   #13
Nice job, drawers and shelves are nice. I'll consider doing that, but with our liner and water tank removed I can shove long items into that space, such as lantern stand and beach umbrella. It's nice to have things organized, but sometimes stuffing it all into the available space works too. Then it's dig through til you find what you want. Thanks for the info & pictures.
Old 01-07-2012, 02:29 PM   #14
Trailer: 1984 UHaul CT13
Great job Tom. You have much more room without the liners.
Patti
keekers is offline   Reply With Quote
Old 01-07-2012, 03:45 PM   #15
Thomas G.'s Avatar
Patti
Thanks.
I'm still looking for a liner for my compartment by the door. I like the way they look and don't mind stashing extra stuff in the nooks and crannies, then putting the liner in place.
Just a neat freak, I guess.
Old 01-07-2012, 08:31 PM   #16
Trailer: U Hall VT
Very nice, good Idea, looks great
Roger Kimble is offline   Reply With Quote
Old 01-25-2012, 07:52 AM   #17
Jane SC's Avatar
Name: Jane and Greg
Trailer: 1985 Uhaul CT
South Carolina
very cool-how about refrig install? UHaul CT
I really appreciate your detailed photos . I just told Greg we needed to think about under sink. Thanks for inspiration.
NOW, we just took out the old icebox(yes, we saved it) and have a dorm frig to install. By chance, did you do this also? If so, pics and DETAILED step by steps would be much appreciated.
Jane SC is offline   Reply With Quote
Old 01-25-2012, 08:46 AM   #18
Thomas G.'s Avatar
No, I plan to mostly dry camp and if I went with a fridge it would have to be propane - which also means cutting some sizable holes in the shell to properly vent it.
My immediate plans are to add 2" of foam insulation on all sides of the current icebox and double up on the gasket, then reevaluate.
I have an irrational aversion to changing anything that can't be retrofitted back to original if desired.
Old 02-11-2012, 09:53 PM   #19
D Davis's Avatar
Trailer: u-haul ct13
Virginia
This is beautiful! A creative way to organize! I like "Out of the Box" thinking.
D Davis is offline   Reply With Quote
uhaul
New UHaul CT13 owner Thomas G. Hi, I am.... 42 04-14-2017 09:32 AM
UHaul CT13 Brakes Thomas G. Towing, Hitching, Axles and Running Gear 83 03-29-2012 08:07 AM
Uhaul ct13 ScottG Classified Archives 1 11-30-2010 12:46 PM
Shelves and drawers in Uhaul CT13 closet Bridget T Modifications, Alterations and Updates 4 08-06-2010 05:21 PM
Towing a UHaul CT13 Mitch Scott Towing, Hitching, Axles and Running Gear 5 04-15-2010 05:11 AM
