Uhaul owners Heads up - Fiberglass RV
Old 09-10-2012, 02:01 PM   #1
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Finally got around to replacing the front two missing Elevator bolts that hold the trailer to the frame this weekend. Since the existing ones were 1/4 20 x2" I upgraded to 5/16 16X2". I punched out the heads of the two that were missing at the frame and found that they had broken off due to corrosion.Since I was going to replace the rest any way I didn't think too much of it as the front gets a lot of water etc. Well to make a long story short All but one of the rest were ready to go. As I attempted to break the nut loose the bolt sheared on all but one. I replaced two of those that rundown on each side of the centerline and they were fine just a little rust. Pictures enclosed for your your amusement. I suspect the perimeter holds more water which wicks into the plywood and facilitates teh corrosion as it looks to occur in that area. New ones were installed with a big dab of the dreaded silicone rubber to make a gasket.I guess it is still pretty good to have lasted 28 years.
Michael j.
mmeyer is offline   Reply With Quote
Old 09-10-2012, 02:35 PM   #2
Trailer: 1984 U-Haul CT-13
wow! looks like i'll be adding that to my list!
themik is offline   Reply With Quote
Old 09-10-2012, 02:38 PM   #3
Thanks for posting that, I'll check mine. Another thing I'm going to look at is the bolt through the tongue to the frame. Bob
mary and bob is online now   Reply With Quote
Old 09-10-2012, 03:33 PM   #4
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I found two broken in the front on mine. Now I need to go check the others.
uhaul
New UHaul Owners, the rPad2 Jane SC Hi, I am.... 25 02-09-2012 07:34 PM
Attention Uhaul owners CindyL Classified Archives 11 01-04-2011 08:29 PM
