Uhaul taillights - Fiberglass RV
Old 08-21-2013, 05:11 PM   #1
tartosuc's Avatar
Trailer: 2007 uhaul ct13
Quebec
Uhaul taillights
Anyone have a picture of the uhaul taillights removed?
Removing mine require drilling the bolts so i would like to see before i start the work.
tartosuc is offline   Reply With Quote
Old 08-21-2013, 06:32 PM   #2
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
here are a couple of pictures of my"spares"
typically screwed through the rubber into the nylon insert.
Michael J.
mmeyer is offline   Reply With Quote
Old 08-21-2013, 07:52 PM   #3
Pam Garlow's Avatar
Trailer: U-Haul 1985
you could get good $$ for those, Mike. Lucky guy to have spares!
Old 08-21-2013, 08:23 PM   #4
tartosuc's Avatar
Quebec
Michael J.
Thanks for the pics....but i'm looking for a pic of the trailer side....sorry for the confusion
Old 08-22-2013, 09:46 AM   #5
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Inside or outside?
Old 08-22-2013, 09:53 AM   #6
tartosuc's Avatar
Quebec
outside
Old 08-22-2013, 11:13 AM   #7
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Here you go
Old 08-22-2013, 11:26 AM   #8
tartosuc's Avatar
Quebec
lol
as i said...i need a pic with them REMOVED!
Old 08-22-2013, 11:43 AM   #9
Trailer: 28' Bigfoot Silver Cloud
Woodstock, IL
I'm a bit confused. On our VT, the screws that hold the lens on go right through the black interior piece and into the fiberglass wall. There aren't any bolts to drill out and the interior piece can come right out. Did a previous owner put in something extra to hold in the interior bulb holder? Mike's VT may not show any bolts either. Maybe a picture of your assembly would help us! Otherwise, the removed assembly just leaves a big hole with four small holes around it for the screws.
Old 08-22-2013, 11:46 AM   #10
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Sorry I guess I didn't understand ,its just a hole in the fiberglass big enough to accept the rubber tail light housing with four nylon inserts in the remaining fiberglass around the perimeter spaced under the screw holes in the lens. you can see the spacing on the original pictures of the rubber housing. From what you describe you have bolts replacing the screws so you need the nylon inserts which are available at any auto parts store or Lowes. I am assuming the PO didn't drill new holes for the bolts. I think there is a picture in theUHaul parts manual available in the document center if you don't already have it, also my spreadsheet with parts info
Old 08-22-2013, 11:53 AM   #11
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I'm pretty sure I've seen photos here of the empty UHaul tail light sockets, but one would need to do a search to find them.
Old 08-22-2013, 12:02 PM   #12
tartosuc's Avatar
Quebec
So is it just attach to the first layer of fiberglass wall or is there another layer under it?
I'm just trying to have a visual of how it is under the taillights before i start my mod, i want to modify the daapters so by seeing how it is under i will know is my idea is doable or not.
Since i need to drill out the screws holding the light due to rust, i dont want to do it just to look under as i will be doing the mod later on ...so I'm looking for a pic to visualize the setup
Old 08-22-2013, 01:25 PM   #13
mmeyer's Avatar
Trailer: U-Haul VT
Indiana
Yep, they just drilled 4 holes in the outer shell inserted the nylon inserts plopped in the rubber housing and screwed the screws through the lens holes and rubber flange on the housing into the nylon.
Be careful drilling as the lens is irreplaceable. I would go in from the inside of the trailer with small side cutters and cut the legs off the inserts , the housing should pop out and you can unscrew the remainder of the nylon off the back. This assumes that from your last post they are screws. If bolts then use a dremel with a cut off wheel or on second thought use it for both options.
Old 08-22-2013, 01:28 PM   #14
tartosuc's Avatar
Quebec
cool thanks for the info.
Old 08-22-2013, 02:57 PM   #15
luvrOlife's Avatar
Trailer: UHaul
Is this the view you were looking for?
Posted from Brooke (Mouse) in April 2012:
Right tail light not working.
-Vanessa
....no matter where you go, there you are!
luvrOlife is offline   Reply With Quote
light, lights, uhaul
Scamp Taillights Brian Bran Problem Solving | Owners Helping Owners 41 02-25-2014 12:07 PM
Dumb question about taillights Chita Problem Solving | Owners Helping Owners 24 02-18-2013 03:08 PM
Replacing taillights Bobbie Mayer Problem Solving | Owners Helping Owners 4 08-02-2012 01:35 PM
LED Taillights D Tharp Problem Solving | Owners Helping Owners 5 06-30-2009 05:50 AM
Trillium taillights georgia g Problem Solving | Owners Helping Owners 17 02-01-2009 05:54 PM
