UHaul Upper Shelf / Loft Project - Fiberglass RV
Old 01-09-2013, 02:06 PM   #1
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I've found that there is not much horizontal space in the CT except for the cushions, so I wanted to add some space to just plop things like a jacket or camera when you walk in the door. Actually the top bunk worked nicely for this, but I took it out for a dinette.
So I added shelves across the front and down the side to the over-stove cabinet. Additionally I added a rear shelf and side shelves. The shelves are made of 3/16" underlayment reinforced with L shaped extruded aluminum. The shelves are painted with exterior mold resistant latex paint matched to the CT's interior color.
No holes were drilled in the fiberglass. Where possible, I used existing holes and aluminum brackets. When necessary, I used an aluminum bracket held in place with 3M Extreme double sided tape.
Old 01-09-2013, 02:11 PM   #2
Thomas G.'s Avatar
Next, I wanted to add an additional barrier to keep things in place should the trailer be moved while the shelves were occupied. I blatantly stole Raz's idea for a shock cord and mesh curtain set up, but first I had to figure out how to suspend the shock cord. I ended up buying turned wooden bases at a hobby store and mounted 1/2" PVC pipe in them. I screwed the bases to the aluminum frame. Each pipe is capped with an eyelet screwed into it to guide the shock cord.
Old 01-09-2013, 02:18 PM   #3
Thomas G.'s Avatar
Next I bought colored mesh material, sewed a tunnel at the top for the shock cord and sewed loop material to the bottom. I used contact cement to glue hook material to the back of the aluminum upright lip and Velcroed the curtain in place. Then I threaded the shock cord through the curtain top edge. I used a spring lock cord holder (like on the bottom of a jacket) to allow me to re-tension the shock cord as necessary. This spring lock is on one end. The other end is fixed.
I also cut out quarter sized pieces of outdoor carpet and glued them over all the stainless steel nuts to eliminate sharp or snaggy surfaces. I also glued some carpet over the aluminum frame in the corners to provide a friendly surface.
Total added weight is about 8 pounds.
Old 01-09-2013, 02:22 PM   #4
Thomas G.'s Avatar
Shock cord spring lock.
Old 01-09-2013, 03:45 PM   #5
Trailer: 17 boler
looks great tom
andrew78 is offline   Reply With Quote
Old 01-09-2013, 03:47 PM   #6
CindyL's Avatar
Illinois
Looks good, Thomas. A while back, Kevin added a hammock-style shelf over the bed in the back where we throw our night clothes. It hangs from eye hooks across the back (not sure if I have a picture though). On our last trip though, he set up the bunkbed in the VT so we could use the top bunk as a shelf too, since he was sleeping in the front bunk due to my elbow surgery recovery. We tend to pile stuff in the front dinette (not great, but it happens), so the bunk gave us a place to throw stuff since we did not have the dinette.
CindyL
CindyL is offline   Reply With Quote
Old 01-09-2013, 04:24 PM   #7
D Davis's Avatar
Trailer: u-haul ct13
Virginia
This is Just the BEES KNEES!!!!! Clever, light weight, and I know it will work! Upper Shelves, Closet Shelves and a Silver Ware drawer is all that is needed for the Uhaul Cts to be Pert Near Perfect. Good Job, Tom.
D Davis is offline   Reply With Quote
Old 01-09-2013, 04:28 PM   #8
Thomas G.'s Avatar
Originally Posted by CindyL View Post
Looks good, Thomas. ........
CindyL
Thanks. The junk's gotta go somewhere.
Old 01-09-2013, 04:34 PM   #9
D Davis's Avatar
Virginia
Tom, when you say underlayment, do you mean the thin plywood that is used under bathroom and kitchen floors? It's lightweight, strong, has little x's on it and looks finished. Where do you find the aluminum brackets? Just curious...
Old 01-09-2013, 04:54 PM   #10
djtriceflt's Avatar
Trailer: 1985 U-Haul CT-13
Less clutter!!!
Mr. Tom,
I had been thinking of modifying some Scamp bins but your design and appearance is even better! Thanks for sharing another of your very practical enhancements!
don '85 CT-13 PEACE be with you!
"Sometimes the hunt is better than the catch"
djtriceflt is offline   Reply With Quote
Old 01-09-2013, 05:12 PM   #11
Thomas G.'s Avatar
Yes the underlayment is just thin plywood used to smooth a floor under linoleum. This didn't have the little x's, but some brands do, to ease layout of tiles. The L shaped extruded aluminum I found at a local metal recycler. The supplier evidently dumps seconds there. The oddly shaped aluminum brackets were just made from aluminum sheet that I also scored at the recyclers. I bent it up in my vice then painted it. I found a local surplus house that sells stainless bolts for $2 a pound, so I splurged on all stainless hardware.
Old 01-09-2013, 05:20 PM   #12
Lil M.'s Avatar
Trailer: '84 13' Scamp & '14 homebuilt Benroy Teardrop
Thumbs up
Looks grrrreat, Tom! Now you got me thinking about adding a front shelf to to LilScamper.
Lil M.
“When one tugs at a single thing in nature, he finds it attached to the rest of the world.” ― John Muir
Lil M. is offline   Reply With Quote
Old 01-09-2013, 05:22 PM   #13
D Davis's Avatar
Virginia
I like salvaging materials...it looks like the frames that hold glass shower doors. Love the modern look of the aluminum metal.
Old 01-09-2013, 05:23 PM   #14
theresa p's Avatar
New Brunswick
nice!!! we made wooden shelves very similarly a couple of years ago. we have a wooden rim but not the mesh. sure has made a difference in storage!
great job. you'll really love how it helps.
uhaul
Converting Scamp 5er Loft peterh Modifications, Alterations and Updates 60 04-14-2017 08:03 PM
Shelf for Uhaul Judith Kennedy Modifications, Alterations and Updates 1 10-27-2009 08:36 AM
1986 Uhaul 17 ft *Project* $2900 Robin G Classified Archives 1 08-13-2009 05:33 AM
GONE - Scamp 19 Loft uprights KamperBob Classified Archives 1 06-19-2007 07:29 PM
Rear Upper Shelf with LED lights. evan Modifications, Alterations and Updates 2 11-20-2005 08:04 PM
» Trailer Showcase
Nut Shell
Sasha
KALEB
jena
