Molded
fiberglass is not a rigid material. Without some kind of support or reinforcement (1) it will gradually lose its original shape, typically sagging at the roof and bulging out at the middle, and (2) it is more vulnerable to a catastrophic failure under heavy snow loads. There are many ways to provide that support.
Scamp,
Boler, and similar designs rely on interior cabinetry. Others use a separate inner shell or structural cored
fiberglass process.
While I won't doubt, Ed, that your
Scamp was built without the galley support, I have to wonder whether it was done at the buyer's request. As far as I have seen, their normal factory build included the support from the start, but Scamp will accommodate many delete requests. One thing they will never leave out is the closet by the door.
The trailer in the photo looks great. It does appear to be a
Boler or clone, but as Ed says it's not certain. If it is, the lack of support on the street side could be a problem. It's not the kind of thing that means instant catastrophe (assuming it is protected from snow loads), but it could be an issue over time. It's also possible the remodel incorporated alternate reinforcement, but I don't see any evidence of it.
Bottom line...
fiberglass shells do need support. There are ways to accomplish that and have an open layout, if you don't mind some work. For a great example, see Ian G's thread
It Started as a Kitchen Reno- Project Boler.
