Used Portable AC in '86 Scamp restoration - Fiberglass RV
Old 05-09-2006, 08:53 PM   #1
Trailer: X-treme Lite 160
I used a Edge Star Portable AC in my restoration of my 1986 Scamp. I have a custom deluxe so the pantry was only 12" wide that I was working with. I cut out the lower portion of the pantry and made room for the AC. I then made 2 straps out of nylon and a couple of plastic latches, all purchased from a local cloth store. The rear of the AC has a 3.5"x 3.75" square exhaust port. As luck would have it, the exhaust port was in direct line with the belly band seam. So, I regrouped and made a box out of sheet metal so I could off set my exterior exhaust boot (a residential dryer termination vent). The AC is 14" x 13.875" x 31". It only weighs 55lbs. and it works great. I measured the amp draw after the installation and it was 8.1 amps just like the spec stated.To complete everything I reworked the original door and made a small closeable cabinet above the AC.What is cool about this , is I can remove the the unit when not camping and put it to use in
our bonus room above the garage. Which is my wifes sewing room and it gets pretty warm up there in the summer months. This was all part of my plan.
I will try to post some photos. I will share more need updates later. Some are pretty cool. Like my door stop!
Thanks,
Gary Little
Gary Little is offline   Reply With Quote
Old 05-10-2006, 05:51 AM   #2
Al & Cindy K's Avatar
Really nice work there Gary! Always interested in seeing what other owners have done so keep posting em!.
Al
Al & Cindy K is offline   Reply With Quote
Old 05-10-2006, 01:08 PM   #3
Brian B-P's Avatar
While I think any air conditoner like this should have an outside air intake (instead of this one-hose solution), this one looks like a nice and compact unit, which could justify the design.
Gary, that's a functional and great looking installation , and I like the multi-use aspect, too .
Old 05-10-2006, 02:02 PM   #4
Thanks Brian.
Gary
Old 05-10-2006, 04:51 PM   #5
Brian B-P's Avatar
The doorstop is slick. Can I assume that the rubber stops hit the hinge mounting plates, not the fiberglass?
Old 05-11-2006, 08:45 PM   #6
Yes. The alignment is perfect. This was my wifes idea. I know it will not help much in the wind, but it is great when loading and unloading at home in the garage.
Thanks,
Gary
portable toilet and portable shower Ruth G Plumbing | Systems and Fixtures 8 04-20-2012 12:36 PM
1977 Scamp 13 Restoration Project ReilleyS Modifications, Alterations and Updates 29 05-14-2011 02:22 PM
1976 scamp restoration DannyH Modifications, Alterations and Updates 21 07-29-2010 03:39 PM
Suggestions needed for restoration of 1980 13ft Scamp Tom & Trisha N. Care and Feeding of Molded Fiberglass Trailers 8 07-12-2008 10:27 AM
Pix of Restoration 13' '77 Scamp Legacy Posts Problem Solving | Owners Helping Owners 7 01-06-2003 12:13 AM
