Vent fan - Fiberglass RV
Old 09-29-2013, 05:29 PM   #1
fusedlight's Avatar
Trailer: 16' 1998 Scamp
Vent fan
5 bucks at the surplus store and parts from the junk bin and I've got an exhaust fan!
fusedlight is offline   Reply With Quote
Old 09-29-2013, 06:02 PM   #2
Trailer: Scamp 16ft
Alabama
How did you mount the fan? I mounted mine on Velcro and tapped into the light for power using 9v battery connecters, I started to install a rocker switch to turn on. 9v connectors worked better for my use 2 fans in/ out.
Darrell in Al is offline   Reply With Quote
Old 09-29-2013, 06:37 PM   #3
fusedlight's Avatar
I open the slider and put the fan in the opening. Close the window to squeeze the fan and flip down the latch. It holds nice and tight. The power is off the light in the cabinet. I split apart an old RCA "Y" adapter and popped one chunk out of the bottom of the cabinet and the other attached to the fan. No switch... I just plug it in. Dorothy pointed out that we shouldn't put the screen on... grease buildup.
Old 09-29-2013, 07:43 PM   #4
This would work well for a bathroom too!
Replace vent fan unit Lfoxmont Hi, I am.... 0 05-31-2013 09:14 PM
Pacer Ceiling Fan Vent Scott Toth Modifications, Alterations and Updates 4 05-31-2013 04:56 AM
Wiring a Vent Fan in a Scamp FlyboyTJ Modifications, Alterations and Updates 2 08-04-2012 06:57 PM
Fan vent that is flush with the roof? Patrick J Modifications, Alterations and Updates 1 09-18-2010 10:57 AM
How *not* to install a fan vent Amy M Problem Solving | Owners Helping Owners 7 02-22-2010 07:32 PM
