VERY IMPORTANT correction to my solar installation - Fiberglass RV
Old 03-08-2009, 04:07 PM   #1
kevin61's Avatar
Trailer: Two 13 ft Bolers and one 17 ft Boler
In my solar installation videos I show a male plug coming from my solar panels.
This is INCORRECT as it poses a serious SHOCK/SHORT HAZARD.
In full sun the red and black prongs on the male connector are HOT.
The plug coming from the panels MUST BE FEMALE to avoid this potential hazard.
kevin61 is offline   Reply With Quote
Old 03-09-2009, 09:10 AM   #2
Trailer: 1993 Bigfoot 17 ftCB / 2011 Toyota Sienna
Kevin;
I think that it should be as shown! Shorting out the solar panel is not nearly as serious as shorting out the connection to the battery, which would then have the Male plug!
For many people the Anderson Power Pole connectors are very suitable for this type of service, as they are bipolar (or genderless) and can serve as either supply or load without fear of shorting.
Using plugs and/or sockets designed for 110VAC in 12VDC applications is NEVER a good idea, for the obvious reason.
Good luck.
Mike .....>
[quote]In my solar installation videos I show a male plug coming from my solar panels.
Attachment 18337
Michael Pupeza is offline   Reply With Quote
Old 04-19-2009, 10:27 PM   #3
I used one of the old four conductor type trailer light kits and just used the insulated conductor and one of the uninsulated conductors on each end so that I never have both poles exposed on the same connector.
Kevin;
Good luck.
Mike .....>
James Wilson is offline   Reply With Quote
Old 04-20-2009, 02:40 AM   #4
Joy A's Avatar
Here's the connection I used for my solar panel. Purchased from West Marine - Marinco Trolling Motor Plug & Receptacle $44.99 It's a locking plug. I plug it in within a minute of putting the panel on the roof and have never had a problem.
[attachment=23488:
120_2017.JPG]
What appears to be a large plate behind the receptable is simply a label above the electrical door. I just drilled the hole in the middle of the label so the receptacle wasn't so obvious.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
solar, solar panel
Rooftop Solar Installation on a 13' Scamp efawcett Problem Solving | Owners Helping Owners 6 07-21-2009 07:15 AM
Solar Charge Controller Installation kevin61 Modifications, Alterations and Updates 3 02-22-2009 08:20 AM
What's more important? Reace General Chat 30 09-30-2008 12:22 PM
A Correction Roger C H Forum Admin, News & Announcements 7 09-27-2008 09:58 PM
A Correction Roger C H General Chat 0 12-31-1969 07:00 PM
