Regarding
window leaks:
If any of the tilt out
windows leak, remove the window, clean and re-seal the mounting flange to the
fiberglass using 3/4" x 1/8" butyl tape, then re-fasten.
If non-opening plexiglass front or back windows leak, remove window, clean edge of window and
fiberglass, and re-install using new rubber molding.
Other possible concerns:
- torsion axles lose shock absorbing capability after 15-20 years (replace axle)
- plywood floors collecting water from
leaks tend to rot over time (repair or replace rotten floors, but also find the leaks)
propane lines should be inspected, leak tested
