Vinyl Click Flooring Some Observations - Fiberglass RV
Old 10-06-2018, 12:36 PM   #1
Trailer: 2013 Escape 19
I am in the process of installing a Shaw branded vinyl click flooring right now. If you are thinking about doing it, I have some comments to share:
1. Not all of it is 100% water proof! There are products that are labeled 100% water proof, and others labeled water resistant. Water resistant to me = Not Water proof.
2. All the boxes of flooring sell for about the same price at Home Depot and Lowes. What does vary is the square footage in the box! Some product had 15 sq ft in a box, others had as much as 27 sq ft in a box!
3. All of the product says just score it and snap it. Easy peasy. Well, bring your razor knife to the store with you and score some of the samples. One product I really liked was thick at 7.5mm. I can tell you it was almost impossible to score and snap. I ended up buying a product that was less than half the thickness.
4. Matching waterproof moldings and transition pieces: this can be a PITA, depending the pattern you pick. I'm still working to round up stair nose for the transition between the vertical wall on the front of the dinette to the horizontal floor on the dinette.
5. You don't have to get it down to a bare surface, but it does need to be level. I pulled out old glued on carpet. Ugh! On the areas that would be exposed, I used acetone to remove all of the glue. But on areas where the floor was going to be laid, I just used a scraper to knock off the high spots.
6. The Shaw product I used is a free floating floor, no glue. I'll be gluing the quarter round, but not to the floor, just to the walls.
Old 10-06-2018, 04:21 PM   #2
It’s in. Just one piece left (1 sq ft). So I used 25 sq ft. Now no pieces are spliced. Each run is its own piece. So I probably wasted 4 or 5 sq ft total, probably a little less. Mine was 3.2mm thick.
Old 10-07-2018, 05:02 AM   #3
bsedwebt's Avatar
Trailer: Casita "Cozy-Casa"
Central Virginia
We need PHOTOS! Pretty please... Sounds like you did a wonderful job though.
"Cozy-Casa" -- Visualize whirled peas
bsedwebt is offline   Reply With Quote
Old 10-07-2018, 05:28 AM   #4
Resort Teak is the color. I wanted something on the lighter side. I will use the poly styrene moldings in a light oak (pretty good match color wise).
I have been pleasantly surprised how good a fake wood vinyl product can look.
1977 Trillium Floor by wrk101, on Flickr
Old 10-07-2018, 05:31 AM   #5
I don't have any before pictures, but it was the hideous red shag carpet others have posted before. Once the carpet was pulled up, I had a mess of mastic. I totally removed it with the help of acetone and a green scrub pad on areas that were going to be exposed: mainly the curved area in the dinette and the short vertical wall step up in front of the dinette.
The rest I just used a hand scraper to knock down the worst of it.
IMG_5464 by wrk101, on Flickr
Old 10-07-2018, 07:26 AM   #6
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Very nice job bill. Apparently Shaw makes a matching stair nose that would probably have to be glued on to the vinyl click flooring at the front edge of dinette.
I am interested in this flooring product and also the waterproof fiberglass backed floating sheet vinyl flooring products on the market for our Boler 17 reno. In our Trillium 4500 we currently have a couple of washable rugs on top of 1/2 inch thick black foam interlocking tiles. Keeps the floor warm during cooler hours/days.
Old 10-10-2018, 11:45 AM   #7
Trailer: Casita 17 FD
Click Vinyl Con
I installed click type flooring in a bedroom in my house. Now I would never use click type flooring in my trailer. Click Vinyl is installed by inserting a tounge into a groove at a 30 - 45 degree angle and swinging it down along the finished edge wall. To do that, the edge piece has to be cut amost half of an inch short of the wall. In a house, the Gap is covered by baseboard and quarter-round. You can't cover the Gap in a trailer that has no baseboard or quarter-round. Also gaps are required around some corners. With all of that I suggest that a glued joint type of flooring can give a better result.
GatorCasita is offline   Reply With Quote
Old 10-10-2018, 12:24 PM   #8
I had none of this problem. I started 1/4 inch away from the kitchen cabinet and worked across to the door. Easy.
I used polystyrene cove which more than covered the gap. I’ll have to measure but it was about 5/8 inch. I laid it out front the door inward so I had a full width at the door and about 5 inches wide at the kitchen cabinet. Then I reversed direction for easy snap in place. I really only left a gap for expansion. I could have just as easily had it tight. The corners in a Trillium are somewhat rounded. With a pair of scissors I rounded the flooring corners. On the cove I relieved the backside of each corner to allow for the rounding.
Additional lessons:
1. If you are going to use cove and plan to use an adhesive, install the adhesive to the fiberglass wall, not to the cove. If you apply to the cove there’s a good chance you will make a mess (don’t ask how I know)!
2. Don’t put cove in front of the doors on the gaucho. First there is nothing to glue to except the floor and I didn’t want to do that. Secondly the doors go down to the floor so any molding is going to catch everytime you take something out through the gaucho doors. The lower door beneath the closet has a fiberglass lip that is higher than the cove so I put it there.
I’ve got to order a piece of stair nosing for the front of the dinette and then I will be done (with this project, the first of many)!
Old 10-10-2018, 01:31 PM   #9
Home Depot sells a flooring called Allure that does not need perfect flat floor to install and it is a floating floor. It does not click together. The clicking flooring has a tendency to unclick so you are always reclicking it. The Allure is thick and each piece sticks to the next. Of course you have to cut pieces at the end walls so the seams are not in line. We did our 600 sq ft living room/dining area, 144 sq ft in kitchen and over 400 sq ft in family room with the Allure. After we did each room we loved it more and more. You can score it and break it at the score. We helped the floor layer by scoring and breaking a lot of the pieces. Of course the samples would not cut and break since they are so tiny. The floor is essentially water proof since each piece glues to the next piece on the ends and sides. It is all pre-glued so you are not gluing any of it. If I ever need to replace the carpet in my Casita I will use the Allure and do it myself since we helped and learned from the floor man.
Old 10-10-2018, 02:41 PM   #10
Yes I looked at the Allure. The Shaw product is very similar, goes over anything, floating floor, etc, I liked the pattern on the Shaw better and it is 100% waterproof while the Allure was water resistant. Really it was a push for me so I went with Shaw. The Shaw box had slightly more sq ft. That worked out well for me as I was able to not have to use pieces to splice in. Instead, each plank is its own separate piece which creates more waste...
Old 10-21-2018, 08:47 AM   #11
Trailer: Beachcomber
I purchased click flooring but havent yet installed it. Ive since read that many people have not had luck with click, and that the flooring must be glued. Perhaps that’s from northern extreme cold users (that includes me in Canadian prairies). I’d thought I’d use construction adhesive when I get around to installing.
Melody beachcomber is offline   Reply With Quote
Old 10-21-2018, 09:16 AM   #12
Trailer: Scamp 16, previously Scamp 13
None
I installed the Allure with the glue strips in my Scamp a couple of years ago. I'm in Michigan most of the year, with trips to Florida. I've also Installed the click connect Shaw flooring in my house. I'm happy with both. The click type does need to be re clicked occasionally, especially the ends of the planks.
Be very careful gluing these floors down. The are meant to float, to allow for expansion and contraction. A few months ago I left my full glass stormdoor closed, with the afternoon sun shining in. About an hour later, I noticed a large "bulge where the flooring in the direct sun expanded but the surrounding floor had not. It flattened back out when I closed the interior door, blocking the intense sun.
All this to say, these floors do need to be able to move around. I'm sure a small area of glue occasionally in a particular problem spot might be ok, but not gluing it all down. I think that would be asking for trouble.
LyleB is offline   Reply With Quote
Old 10-21-2018, 01:15 PM   #13
This type of flooring is not meant to be glued down. It is called a floating floor. It needs to move some with the temperatures. Gluing down may give you some real headaches. Go with the Allure flooring that glues itself to each piece. It can be found at Home Depot. We've done over 1200 sq ft of it in our house and it is wonderful. It is about water proof since the sides and ends glue to the next piece. Leave about 1/8 inch on each wall side and end for the floor to move if need be for the change in temps. Do not put molding tight to the flooring. Just let it barely touch the flooring. The click type will unclick especially when pulling the trailer. If it unclicks that would make it totally not water proof since the water would go into every spot that isn't sealed.
Old 10-21-2018, 01:27 PM   #14
I have not seen the click type flooring at Home Depot. We did go to Lowe's and saw it. Our floor guy said to use the Allure especially if our floor may have imperfections or high and low spots. It does and the Allure forms to these spots. Home Depot's flooring that looks like what you have is Allure and it glues itself to the next piece at ends and sides. We love it in our home. Since it glues itself to the next piece it is most likely not 100% waterproof since I'm sure there are minute cracks where the pieces join together but it is likely not to let water in unless you leave it standing for quite a while. If you got a lot of water such as a broken pipe flooding it is easy to pull up in a solid full piece and let it dry at the bottom. Since the trailers are so small you could pull up the flooring by removing the moldings and lifting the entire floor area out.
Old 10-21-2018, 01:38 PM   #15
Name: Cate & Dan
Trailer: 1976 Triple E SurfSide "The Mutt Hut"
Manitoba
I have Allure in my kitchen and had a leaking faucet line which caused a small pool right on a seam and it did lift at the seam and get into the subfloor. I ended up lifting that section and repairing the subfloor and they make a seam tape for just such a repair so I am not particularly confident. I have click flooring at the back door and track all kinds of snow etc. without issue. That being said the floor is only waterproof to small amounts of water. Because it floats, there is the opportunity for liquid to seep under the edges if enough is present, like where you drop a pitcher of margaritas (heaven forbid) or the dog knocks over the mop bucket. I plan on installing click flooring in our trailer but am looking at using a silicone based caulk to seal the moulding to the floor. Will probably use the clear stuff that is used for windows and doors as it stays flexible at all kinds of temperatures which should allow for expansion and contraction. I did this with seams at the rise and run on my stairs and it has held really nicely. I used brown caulk there to match the floor.
Old Macdonalds is offline   Reply With Quote
Old 10-21-2018, 02:28 PM   #16
Its waterproof in respect to you could soak it in a tub of water and it won't absorb any water. As far as water passing through it, you bet. Its waterproof, but not a water barrier. Even the gaps you leave along the edges will allow water to pass below the floor, as is true for anything you have to leave an expansion gap around.
Many flooring products themselves can be affected by moisture.
Old 10-21-2018, 07:52 PM   #17
I’ve already bought the click flooring. No plans to buy something else,
Old 10-21-2018, 07:55 PM   #18
David B.'s Avatar
Exactly. I had intalled Allure flooring in our Scamp, and only a couple weeks later I spilled a pitcher of water on it and the floor under it just simply would not dry out, even here in the hot, dry, Arizona summer with fans blowing over the floor 24 7. I had to remove the flooring and dry it off. A couple months later the wife dropped a pan of liquid, and I had to take it up again to dry the flooring of the Scamp. In our Lil Snoozy I’m in the process of putting down cushy interlocking 3’x3’ anti-fatigue matts that have nickle sized holes throughout it’s pattern (for water to be able to run through and then later let evaperation take place). I plan to put down the type of “carpet” that is frequently used beneath RV awnings outdoors, over top of the unattractive tiles. Time will tell if this works out well.
Dave & Paula
vin
Don't click on that big green "Start Now" button at the top of the page Bruce H Forum Admin, News & Announcements 4 09-04-2018 02:23 PM
Glue for vinyl to vinyl Cmtravels Problem Solving | Owners Helping Owners 8 08-14-2015 06:18 AM
Towing Escape 15 trailer with 4 cylinder to Alaska - Performance Observations dotllama Towing, Hitching, Axles and Running Gear 23 04-11-2013 02:23 PM
Observations upon installing LED interior lights rabbit Modifications, Alterations and Updates 0 08-04-2011 06:22 PM
Ooops...sometimes I click before I think... scott fraser General Chat 0 08-15-2007 06:40 AM
