Vinyl Flooring help - Fiberglass RV
Old 04-21-2007, 07:36 AM   #1
Nicole M.'s Avatar
Trailer: 1981 Trillium 4500
We are putting a sheet of vinyl flooring in our trailer and are wondering what to do with the little step to the dinette area?
Do we cover it, too? Just seems that it might be a bit bulky. Or do we cut the sheet so we have 2 peices? Then what do we do with that vertical area? Leave it as is?
Thanks!
Nicole M. is offline   Reply With Quote
Old 04-21-2007, 09:11 AM   #2
Jeanne and Steve's Avatar
Trailer: Casita 16 ft 1984 and U-Haul CT13 1985
Hi Nicole,
I don't have a good answer to your question, however, have you thought of having carpet on the vertical rise and area under the dinette/bed? We left our original carpet and just put new flooring on the main section of our Casita, and are really happy with it.
Jeanne
Jeanne and Steve is offline   Reply With Quote
Old 04-21-2007, 09:27 AM   #3
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Our Trillium has custom bound grey carpet pieces for both areas, the main floor and the area under the bed/table. We had originally made the under table piece long enough to fold over (and cover) the "toe stubber" but soon found that without more carpet surgery, this was not a viable way to go for us. Wanting to keep the carpet removeable for ease of cleaning, we ended up cutting that overhanging piece of carpet off, leaving the raised kickplate exposed. I presume one could cover this area with almost any material, from a nice piece of wood to a highly polished piece of stainless steel.
For now, at least, we are just going to keep ours painted to match the other expossed glass parts of the trailer. I know its only going to get scuffed and abused anyway, but what the heck......???
Old 04-21-2007, 10:01 AM   #4
Greg A's Avatar
Trailer: 2015 Escape 19
I'm right in the middle of the flooring and just was working on that section last night. I am using the new vinyl wood laminate at Home Depot. Really awesome product for RV applications and a breeze to install. If you haven't totally committed to the vinyl sheet you might want to take a look at this product.
Attached I'm using an aluminum "L" to trim out the riser section and I have another aluminum "L" for the bottom of the riser. This matches the new aluminum columns I'm using for the table. You can pick up the "L" at any hardware store and cut to fit.
Hope that gives you some ideas.
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 04-21-2007, 02:55 PM   #5
Trailer: 1999 Scamp 16 ft ('The Pod')
The previous owner of our 99 Scamp had the factory install vinyl flooring before it was an option, and they used the same riser and edging method as Greg. We have owned the trailer six years and the flooring has held up well. The perimeter is caulked with the same weird caulking that was used on the rest of the trailer and that may have to be redone soon. Some kind of molding might look better.
Vivian
Vivian is offline   Reply With Quote
foam backed vinyl Harry Young General Chat 2 08-09-2015 09:04 PM
New Flooring-Laminate or Vinyl Tim Wood Care and Feeding of Molded Fiberglass Trailers 49 03-08-2015 03:11 PM
Dying vinyl Dave Bese Problem Solving | Owners Helping Owners 6 04-20-2010 10:05 PM
GONE - Compact II vinyl logo shellyc Classified Archives 12 10-31-2008 01:51 PM
That vinyl stuff around the windows Legacy Posts Problem Solving | Owners Helping Owners 6 08-29-2008 09:14 AM
