Originally Posted by ScampMin
Next camping season I'm planning on removing the carpet from my 13' Scamp and installing vinyl floor planks (wood style) but need some advice on installation type. I learned by looking on the internet that you can install the planks with a glue adhesive, a peel and stick plank or you can use what is called a floating style plank do does not require adhesive. What i have not been able to find clearly on the internet is what type works better in an rv, a Scamp with plywood floors to be more specific. I did read that you have to take factors such as vibration from motion, temperature changes, and moisture into consideration as any of these can cause buckling or warping. Does anyone have some advice on this?
Sorry if I misunderstand whether you mean the rigid flooring or the flexible,I have used the rigid variety with good success and I think it may even strengthen the subfloor (no real evidence to that effect).
I have installed the snap together vinyl surfaced flooring on several Scamps including Eggy-Sue.
You can simply remove the carpet, cut the lengths and snap the floor together, when it is installed it will lay flat.
I went two steps further with my trailer...
1] I went ahead and stapled around the perimeter using crown staples under the mop-board .
2] After installation I coated the floor with industrial grade floor wax.
The wax prevents moisture infiltration and it also is renewed with a simple diluted wipe down.
Mine has been excellent for probably 5-6 years.
Another point to consider...
Do the main entry floor only, that's where all the wear and cleanup is. Leaving the step up area under the dinette will make it more comfortable on your feet and looks nice as well.
Also, it is easier and cheaper, while accomplishing the same goal.
The first two pictures are of Eggy-Sue, Its hard to see in the picture but the front of the step-up is still carpeted, only the floor is planked.
The second two pictures are from the "Shelly" project.
