On the
Trillium that I owned, there were two taps.
One worked with water from the aqueduct and the other was accompanied by a small pump from the tap to use the water from the tank ...
It all depends on how you want to use it.
If you have 12-volt water pump, you need only one hole for the cold water tap, make the connections under the cabinel.
It is to each his convenience.
