Water Level - Fiberglass RV
Old 11-15-2005, 05:56 AM   #1
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Here's a no-brainer if you have visual access to your water tank and you can see the water level through the sides.
Start with it empty and add some convenient amount of water. I have a 25 gallon tank so I added 5 gallons at a time. Mark the level then add some more. A quick pop of the side storage door gives me an idea of whether I have to make a water run while boon docking. Not a biggie.
I travel with only 5 gallons in the water tank and when filling before a trip with the water hose this gives me a guide. (Trivia: Did you know that the Casita 16 is longer behind the axle than the Casita 17'. Makes water behind the axle a bit more of an issue due to the lever arm.)
There are water level sensors but for my needs this was sufficient.
Quando omni flunkus, moritati
Old 11-15-2005, 07:12 AM   #2
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
Hi Steve, I never knew that but that must be where the extra 100 lbs of tongue weight comes in on the 17'ers
Love being Inneggsile
heading sloowly up the eastcoast to our next 2 month (Aug and Sept) camp hosting gig at Camden Hills State Park in Maine
Bill MacDermod is offline   Reply With Quote
Old 11-15-2005, 07:48 AM   #3
Steve L.'s Avatar
FWIW; Recently, I noticed how the 25 gallon tank virtually blocks the outside storage cubby on the 17 while I have some storage on my 16. At the get together in Brown County recently, I was looking at the other side of the different trailers and I noticed the battery door, the water heater and the shore power door seem to be in the same relationship to each other on both size trailers but that there was more body between the shore power door and the back of the wheel well on the 16 footer.
On The Level Gerry Care and Feeding of Molded Fiberglass Trailers 7 11-07-2007 03:24 AM
How level is level? DaveK Problem Solving | Owners Helping Owners 8 06-06-2007 11:03 AM
Will you Level with me? Frederick L. Simson General Chat 28 11-26-2006 01:00 PM
Propane tank Level? Byron Kinnaman Problem Solving | Owners Helping Owners 32 12-23-2005 10:57 AM
new level and power gauges Joe MacDonald Modifications, Alterations and Updates 8 12-12-2005 05:37 AM
