Water pump install ?'s - Fiberglass RV
Old 03-14-2015, 07:23 PM   #1
Trailer: Trillium 4500
Where I'm am:
First off I only boondock. I just broke my trusty hand pump (don't try to pump when you know that the tank is frozen; duh). My electrical system is pretty dialed with 2 6V's and a 150w panel, powering very little.
Where I want to be eventually:
12V pump supplying water to the sink and an outdoor heated shower via a propane water heater.
I can't afford to do this mod all at once but, I figured that the broken hand pump is a good reason to get it started. I'd like to install a 12V pump to bring water to my sink from my on board tank and I'd like to make sure that it is ready for the next phase (water heater and shower) down the road.
Not sure where to start. Any advise on pumps, faucets, installation, and down the road compatibility would be great!
Yes, I realize that after this mod I'll have to"winterize"
Thanks!
Scott H is offline   Reply With Quote
Old 03-15-2015, 01:03 AM   #2
Trailer: Fiber Stream
Red face Silence is golden (and spendy)
I replaced the aged water pump in my Fiber Stream with a top-of-the-line Sure-flo "Whisper King" combined with an expansion tank and flex hoses. (Note: the opaque plastic water line, in either gray or white, while bendable is NOT flexible enough to isolate pump vibration). The floor is carpet. I can run water without waking my sleeping partner.
In my Compact Jr. restoration, I installed a budget Flow-jet pump without the expansion tank, but with the flex hoses. The floor is hard fiberglass "FRP" panel. It sounds like a semi-truck's jake brake and will wake the dead.
BOTH pumps have rubber mounts.
Old 03-15-2015, 08:13 AM   #3
I have installed three "SeaFlow" pumps in the past few months for fresh water pumping in pop-up tent trailers as well as in my Hunter Compact-II, and found them more than adequate for the task, especially considering the very low price. Here's that pump on eBay where I bought them:
RV Marine Boat 12V 1 2GPM 35PSI Water Pressure Diaphragm Self Priming Pump | eBay
However I don't think that they have enough volume for a Hot/Cold system with a shower. For that I would use a Sure_Flo, albeit @ 3X the price.
I will try to find the link to my Hunter install and post it next,
Old 03-15-2015, 08:18 AM   #4
Sea FlowPump Installation
Here's a link to the installation in my Hunter:
Another Answer to Fresh Water
Old 03-15-2015, 09:32 AM   #5
Trailer: Triple E
Sure flo is a well known rv pump make, and very common. They are also repairable if you have some mechanical expertise. Be sure to use flexible hose to absorb vibrations, and, even though the Sure Flo is a positive displacement pump, it is wise to mount the pump with the inlet as low to floor as possible, to ensure that you have water at the inlet simply by gravity. A direct line to the inlet that does not go up and over something, such as a fender well, will serve you best. An expansion tank with an air chamber will help even out the flow, but is not essential.
Gerry
Gerry Kiernan is offline   Reply With Quote
Old 03-15-2015, 11:39 AM   #6
FWIW: At least when new, the Sea Flo can draw water up about 16" unprimed.
Old 03-16-2015, 08:38 AM   #7
Trailer: Triple E
As I mentioned, the Shur-Flo is also a positive displacement pump. However, on my old Vanguard the supply line was routed from the water tank, up over the fender well, and down to the pump. In the Spring, when I would refill the water tank, and prime the lines, it could take quite an effort to get the pump primed. Once primed it was fine. Now, this pump probably had a lot of hours on it, and perhaps when it was new and shiny that might not have been a problem.
But, It also seemed a very poor plan to introduce a cavitation point in the supply line by deliberately running it up and over the fender well. It created a problem that was totally unnecessary
Gerry
Old 03-16-2015, 09:08 PM   #8
Denece's Avatar
Trailer: Compact II
I must be the oddball, but I think it comes from living aboard a cruising sailboat for 8 years.
The first thing I wanted when we got our CompactII was to remove the inoperable hand pump AND the 12v pump and put in a foot pump and spigot.
This sounds peculiar, but let me continue.
12v pumps are notorious power hogs and noisy. Worse yet, if you have the tiniest leak they can drain both fresh water and battery.
A foot pump allows you to wash both hands at once while consuming no power.
(This presumes no hot water heater. I lived 8 years without one yet showered regularly. All you need is a tea kettle and a pump garden sprayer.)
Save power. We boondock regularly with 40 watts of solar panels, charge up everyone's electronics, use all the fans and LED lights we want.
It's one way to go
YMMV
DENECE
Denece is offline   Reply With Quote
Old 03-16-2015, 10:07 PM   #9
I don't know what pumps you may have used, but our experience is just about the opposite.
We have two pressure demand pumps in our Compact-II, one for the regular cold/hot water system, the other to deliver fresh water from a separate container, and find that the convenience trumps any of the disadvantages.
We also have ON/OFF switches for both and be sure that they are turned OFF when we leave the trailer. Power use and noise are minimal.
Old 03-17-2015, 04:16 AM   #10
Raz
Raz's Avatar
Vermont
It's one way to go
YMMV
DENECE
I don't think it's odd at all. It would fit our style of camping too. Adding a foot pump was one of the first things Maggie asked for. Unfortunately the position of the refrigerator right below the sink makes a clean installation challenging. Raz
Old 03-17-2015, 08:42 AM   #11
Trailer: 13 ft Scamp
Could someone post photos and instructions for a foot pump? I've never seen one and am intrigued! Thank you.
Darnelle is offline   Reply With Quote
Old 03-17-2015, 03:02 PM   #12
Love the foot pump!
Whale Marine - Products
David Schroeder is offline   Reply With Quote
Old 03-17-2015, 06:16 PM   #13
Looks like the manual foot pump costs a lot more than a pressure demand pump. The Sea Flo I used was about 1/4th the price, see post #4. But, if cost were not a consideration it sure beats the hand lever type pump.
Amazon.com : Whale GUSHER GALLEY MK 3 PUMP : Boating Bilge Pumps : Sports & Outdoors
Old 03-17-2015, 07:00 PM   #14
Denece's Avatar
Trailer: Compact II
I got mine from West Marine for under $50. We have yet to plug our CompactII into shore power since we got it. If you normally camp in improved campgrounds with hook-ups it wouldn't make sense, I agree. That just isn't how we do it.
Denece
Water Pump Diane H Problem Solving | Owners Helping Owners 10 07-19-2013 07:09 PM
Noisy water pump. peterh Problem Solving | Owners Helping Owners 20 04-20-2011 02:42 PM
water pump switch lloyd cicetti General Chat 5 03-18-2009 08:33 PM
broken hand water pump cyndi H Problem Solving | Owners Helping Owners 21 10-21-2008 05:58 AM
Water pump install Al Stansell Modifications, Alterations and Updates 11 01-18-2006 05:07 PM
