Originally Posted by wxmixte
Does anyone have an off-grid water system (clean water tank/gray water tank) in a Burro/Scamp/similar 13' trailer?
13ft Playpac
I put a 30 gallon fresh water tank under one of the dinette seats with a 12v pump on it to pressurize the system.
I have a single 8 gallon tank for the waste that sits on the floor in the closet, with a hole for the waste pipe leading out below to a standard RV waste valve. Including the waste pipe I'll guess its about a 10 gallon situation. The little tank has a re-enforced top on it so the toilet sits on it, making it the same height as the one at home. I'll set the 30 gallon blue campground waste tote outside next to the outlet for the weekend so I can dump the tank a few times before dragging the tote to the station.
The sink will also drain into that one tank. I figure the sink will be for hand-washing and teeth brushing so not a lot of added waste water from that.
I have plumbed an exterior spigot to use for a portable water heater and an outdoor shower pop-up teepee, so that water is just going to go on the ground. We use paper plates and plastic dinnerware when camping so minimal dish-washing of a griddle or two will occur on the side there by the shower too.
You can see pictures of whats been done so far in the build thread in my signature.
