Water Tank Filler - Fiberglass RV
Old 09-05-2013, 09:37 AM   #1
Trailer: Currently Shopping
Water Tank Filler
I have a 76 Boler and the water fill valve (mechanism) is rather a pain in the butt. The gasket seal was gone when I bought it, and I tried to cut some new ones, but they did not work out so well.
I would like to replace the whole fill port. I am looking for suggestions/pictures/links of what others have used.
Cheers!
Dave
davelikebike is offline   Reply With Quote
Old 09-05-2013, 09:23 PM   #2
Hi Dave, there are many solutions from locking (with pullout filler), to what Scamp uses.. which the entire thing sits on the outside of the body.
Are you looking to replace something similar to the aluminum body filler that may have been original to your Boler (similar to the plastic Scamp)... or what? Basically, what are your expectations?
Old 09-06-2013, 07:24 AM   #3
Thanks Donna.
I am really looking at the two options:
Gravity Water Tank Fill Spout Flush Mount RV Camper | eBay
and
RV camper Trailer Marine Gravity Water Fill Dish New L | eBay
The second one is similar to the original Boler one I currently have on my camper. I find it slow to fill and like I mentioned my gasket is gone.
Just wondering what people recommend. Is one better or easier to fill than the other?
Who likes what?
Cheers!
Dave
Old 09-06-2013, 07:32 AM   #4
Dave, The filler you select will depend on on how you fill your tank. The first kind is great if you are always going to fill your tank with a hose. The second kind, which I call the pelican beak, will work a lot better if you're ever out somewhere and need to use a bucket.
My Casita has the second kind and it's come in handy when I've been boondocking. The biggest disadvantage I've found is that the overflow hose hangs straight down and tends to lose water when I travel. So I've learned to block it with a small rubber stopper while in transit.
Terry G is offline   Reply With Quote
Old 09-06-2013, 07:52 AM   #5
I use the straight in "hose fill" port on all my trailers. But... I also take a large funnel and, using a couple pieces of 1/2" or 3/4" PVC and some elbow fittings, make an adapter that lets me fill the tank from a bucket using the funnel.
Old 09-06-2013, 07:53 AM   #6
Thanks everyone, that's the kind of info I was looking for.
Cheers!
Dave
Water filler cover broken Janb313 Problem Solving | Owners Helping Owners 30 03-09-2013 05:25 PM
leak at filler tube on freshwater tank Doghaus Problem Solving | Owners Helping Owners 22 11-03-2012 05:20 PM
Flush Mount Water Filler Deb & Chuck Commercial Posts and Products 3 05-25-2012 05:31 PM
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 6 05-20-2011 08:19 AM
Water filler and cord access Gary Z Care and Feeding of Molded Fiberglass Trailers 3 03-30-2009 12:50 PM
