Since acquiring a 1987 13'
Scamp about 3 years ago, it has gone thru a series of changes all designed to enhance its livability and improved appearance. First all manufacturer and prior owner decals were removed and 2" wide 3M striping tape applied below the shell parting line in three colors, ABS wheel covers were added to
tires rims and spare and a 13" white spare tire and
propane tank cover added. Then the changes started. The list is long and I will enumerate a few of the them without posting pictures or descriptions of them. If anyone sees one that they might be interested in make a post and I will set up a picture and brief description. With this post is a shot of the dining table rework to increase the clearance between the table corner and the sink counter. We found it a bit difficult to squeeze into the seat with the original clearance of about 8". So to increase the clearance to 12", 4" was cut off the back end of the table, hardware reinstalled and a filler board fitted to the front of the seats to accommadate the cushions when in the bed setup. Hardly notice the loss of table top surface and it sure is easier to get seated.
Here's the list of mods:
1. Stereo sound system, CB/Weather Radio & switchable PS
2. Gravel guard conversion to
awning
3.
Solar Battery maintainer mounted on gravel guard
4. Ceramic heater built into lower RH cabinet
5. Kitchen utensil drawer & pull out paper towel holder
6. Holmes remote controlled twin fan in roof hatch
7. 3-way sink faucet, soap dispenser,splash guard & SS sink &
stove covers.
8. Fold down counter extension, right side of counter.
9. Replacement of original "icebox" w/ Coleman Cooler
10.
Propane system update with new tank, 2 stage regulator &
flexible connection to current RV gas standards.
11.Carefree of Colorado 8' Sidewinder
awning
12.Remake of screen door installed by previous owner and added
privacy blinds
13.Entrance door holder to keep in open position
14.Repositioning of interior 110VAC flourescent fixture from side
wall to under overhead cabinets 12VDC fixture added.
15.110VAC socket added to RH side stove cabinet, interior of
wardrobe cabinet to power ceiling fan and
Microwave.
Additional weatherproof outlet added below curbside window.
16. Disconnect of Shore cable from CB box and conversion to
exterior plug with GFI.
17. Removable rack below curbside window for Coleman
propane
stove for convenient outside cooking.
18. Recarpeting of floor w/ SS kickplate on riser.
19. PVC rear bumper extension & new
tail lights w/ amber turn
signals.
20. Roof mounted Wintenna "Boomerrang" TV antenna & CB
antenna.
21. Audiovox VE-550 dropdown color TV mounted under RH
overhead extension. (installation in process)
This is quite an extensive list but we feel our little egg is right up to snuff and very comfortable. We enjoy it and hope you will to. Incidently she is towed by a 90HP VW Vanagon Westfalia. See them both at <http://users.erols.com/nesu>
Nevin Lescher<img src=http://www.fiberglassrv.com/board/uploads/3dfd434bbaf4012 inch clearance.JPG/> <img src=http://www.fiberglassrv.com/board/uploads/3dfd44483d366Filler Board for bed setup.JPG/> <img src=http://www.fiberglassrv.com/board/uploads/3dfd447a5465eDinner for Two.JPG/>
Here's a shot of the Stereo Sound System<img src=http://www.fiberglassrv.com/board/uploads/3e03d11790289RH Cab Ext w 12V PS
Battery Switch and Stereo.JPG/>
And 3-way Sink Faucet, Soap Dispenser & SS Sink Cover<img src=http://www.fiberglassrv.com/board/uploads/3e03d22f0e4b3Sink w 3way Faucet Soap Disp Splash Guard.JPG/> <img src=http://www.fiberglassrv.com/board/uploads/3e03d25790ae3Sink with SS Cover.JPG/>
Gravel Guard in
Awning Setup w/
Solar Panel<img src=http://www.fiberglassrv.com/board/uploads/3e03d6f48246aGravel Shield Open.JPG/> <img src=http://www.fiberglassrv.com/board/uploads/3e03d74ad03feSolar Panel and Boomerang Ant.JPG/> <img src=http://www.fiberglassrv.com/board/uploads/3e03d76daefd6Westy II, Gravel Shield Down.JPG/>
Utensil Drawer & Towel Holder<img src=http://www.fiberglassrv.com/board/uploads/3e03da2b4c381Utensil Drawer Towel Holder.JPG/>
Shore Cable Modification w/ GFI<img src=http://www.fiberglassrv.com/board/uploads/3e03da8c64b92Shore Cable Plug andGFI.JPG/> <img src=http://www.fiberglassrv.com/board/uploads/3e03dabd6ae19Shore Cable Plugged in.JPG/>
Screen Door w/Privacy Blind<img src=http://www.fiberglassrv.com/board/uploads/3e03db1d43de1Screen Door with privacy blind.JPG/>
Electric Heater & Coleman Cooler<img src=http://www.fiberglassrv.com/board/uploads/3e03dbc42ae53Electric Heater Coleman Cooler.JPG/>
