What am I getting into ? - Fiberglass RV
Old 07-09-2016, 07:51 PM   #1
Trailer: Cadet
New Brunswick
We just bought a 1986 Cadet. The ugly gold fabric on the walls has come unstuck from the disintegrating thin foam behind it, which is revealing some sort of glue residue on the fibreglass. I would like to remove all this gunk but not sure how to proceed and what toxins I am exposing myself too. Providing I can somehow get back to the fibreglass shell, should I just paint it or maybe glue on thin styrofoam and new fabric ? Somebody must have figured this out and done it successfully...
minihorse is offline   Reply With Quote
Old 07-09-2016, 09:14 PM   #2
David Tilston's Avatar
Welcome Kathi!
The current standard for wall coverings in a fibreglass trailer is marine head liner, sometimes called Rat Fur. This goes over Reflectix, a silver foil bubble wrap. It is light, and lasts. Ii provides a small amount of insulation, to help keep the condensation down.
As for stripping it down to the fibreglass, I got nothing. Hopefully someone will comment on that.
Old 07-09-2016, 10:28 PM   #3
Trailer: Shopping
Alabama
You should check out Rookie vs 1990 casita in the project forum. He has taken his casita down to the bare bones you'll learn a lot
Good luck
Marion
Marion is offline   Reply With Quote
Old 07-10-2016, 10:57 AM   #4
vintageracer's Avatar
Trailer: Uhaul
Open ALL the windows, get a BIG fan to blow air through the trailer, get a charcoal type respirator/air mask, get some lacquer thinner and remove the glue from the smooth fiberglass surface. NO need to remove any fiberglass or gelcoat surface from the fiberglass.
No it's actually not that bad of a job to remove the contact cement/glue from the smooth fiberglass surface of the inside of the trailer from which you just removed the wall covering just "smelly" because of the lacquer thinner. A flat plastic "Bondo" spreader or similar item helps to scrape and remove the thinner softened glue without damaging the fiberglass surface. Wipe the fiberglass down AFTER removing the glue with your favorite smelling disinfectant, let the trailer continue to air out a day or 2 and you are done!
For all the old foam from your old wall covering that is still there after peeling off the wall covering I have found getting a big brick of foam or a big sponge and rubbing what's left of the old foam with these will quickly remove the old foam from headliners and your fiberglass wall leaving only the glue and some foam residue to deal with using the lacquer thinner and scrub process.
vintageracer is offline   Reply With Quote
Old 07-10-2016, 01:48 PM   #5
Trailer: Cadet
New Brunswick
[QUOTE=David Tilston;597267]Welcome Kathi!
It sounds like our Home Hardware store has this. Might be a dumb question but which side does the foil side go, to the inside of the trailer or the fibreglass ? Would I put this on with contact cement ?
Old 07-11-2016, 09:30 AM   #6
Trailer: 2014 Scamp 16, 2011 RAV4 V6
Kathi,
I feel your pain. I ran into exactly the same thing while redoing a Hunter Compact Ii. After trying peeling with my fingers and messy solvents, I tried a wire brush wheel on an electric drill. It worked great and did not damage the fiberglass.
Doug in Sacramento is offline   Reply With Quote
Old 07-11-2016, 11:04 AM   #7
Trailer: Cadet
New Brunswick
cadet reno
People are wonderfully helpful on this site ! I will try the wire brush on the drill as I am super sensitive to solvents. Anxious to get this baby home, our truck ball is too small at 1 7/8 and no amount of power assisted wrenching will unstick the nut, bonded to the bolt with rust. Will be landing it home with a neighbor's truck tonite. Then let the reno begin !
Question for you: getting trailer into/out of garage w/ 7 ft. door? Kathy T Hi, I am.... 25 07-15-2015 03:24 PM
Getting Trillium into garage bluenorth Problem Solving | Owners Helping Owners 7 05-31-2013 07:24 AM
Just getting back into trailering Childs in Texas Hi, I am.... 12 09-28-2011 01:33 PM
dollies for getting your trailer into the garage Scott S. Modifications, Alterations and Updates 19 09-18-2010 08:01 PM
Running the battery into oblivion Gina D. Care and Feeding of Molded Fiberglass Trailers 11 12-02-2005 01:00 PM
