What to replace a fridge door panel with? - Fiberglass RV
Old 04-14-2011, 02:26 PM   #1
I want to update the front panel on my fridge -to black or something that looks stainless and wondered what products others have used to do this.
I know I can paint it but I also know that when you paint that type of surface it tends to scratch up pretty fast - but if anyone has a way of painting that will last I would be intreasting in hearing what type of paint to use.
Old 04-14-2011, 04:17 PM   #2
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
I took the door apart and cut a piece of thin plywood to fit in the fridge door rails and painted it high gloss black. I have seen guys do the same thing with diamond plate. You can also buy rolls of stainless steel and cut it to fit.
Rick Mooyman is offline   Reply With Quote
Old 04-14-2011, 04:35 PM   #3
Trailer: Fiber Stream
Cool
What does your fridge look like now, is it white?
Mine has a piece of paneling to match the wall paneling of the cabinet.
I have seen pictures of fridges that had a mirror in the slot for a panel.
A piece of stainless could be inserted there too, but I'll have to try to find a link to my source...
Old 04-14-2011, 05:28 PM   #4
It has a sheet of what appears to be melamine in it now.
Where would one buy a small sheet of stainless steel?
Old 04-14-2011, 07:06 PM   #5
Big Box stores like Lowes and Home Depot sell metal in sheets. I've seen aluminum and diamond plate (for certain), not sure about stainless steel... because I never paid THAT much attention. I have a Metal Supermarket about 2 miles from me. This is where I get metal product. YMMV
Basically Carol, you can put ANYTHING in that spot as long as it's the same (or close) thickness.
Old 04-14-2011, 07:30 PM   #6
Trailer: Casita 16'
Wisconsin
Spray Paint
Carol,
I recently had an alumalite panel inserted for a front refrig door. It was a panel of MDF, but I asked that a panel of white alumalite be placed there.
So many people have said it looks great.
But...You would like stainless steel. I used (Indoor/Outdoor)x-o Rust, Professional Paint and Primer in One, to spray table legs and bunk supports. You could try painting the existing panel with the same product. I do encourage you to use some type of a top coat to protect the finish.Good luck! Mona
monasimpson is offline   Reply With Quote
Old 04-14-2011, 09:00 PM   #7
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
I went to our local 'Home Hardware' outlet, they let me rummage through some units that were destined for the recycler. I was able to find 2 machines that had removeable panels, BOTH had two panels back to back with different color options. I was able to take them home with me and swapped them off with the panel that was on the fridge to begin with. You could also go direct to the recycler yourself and see if they let you 'liberate' parts.... One problem I found with our 'on the floor' fridge is that the door panels are very pone to scratches!
Old 04-14-2011, 09:36 PM   #8
Trailer: 13 ft Ventura
I replaced the wood fridge panel with a glossy white piece of plastic sheet material called arena board. It's made for taking hits from hockey pucks - so it an take any beating that we give it in the trailer. I expect it might come in other colours too.
Darrell O is offline   Reply With Quote
Old 04-15-2011, 10:30 AM   #9
Trailer: (4) Trillium 4500, (4) Trillium 1300, (1) Scamp,(1) Burro 16'
Ardmore, Alabama
The 2 options I've used....FRP panels (FIBERGLASS REINFORCED PANELS) comes in different colors, thin, has a peeble finish and is pretty much indestructible.. This is the same stuff I used to build the overhead cabinets out of in the Trillium Renov. thread I started on here if you would like to see a picture of the stuff......On another camper I found a roll of wood grain shevling paper made of vinyl that was sticky on the back (something like wood grain wall paper) at a yard sale for a dollar and it matched the wood flooring I had put in the camper perfectly so I used that and it has stood up great also............Just a couple suggestions..RANDY
Randy Bishop is offline   Reply With Quote
Old 04-15-2011, 10:42 AM   #10
*Thanks* everyone for the great suggestions - will have to get out and start looking at some of this stuff.
Old 04-15-2011, 12:00 PM   #11
Rarebird's Avatar
Trailer: Trillium 4500
fridge door
Hi,
In my boler I painted the door with chaulk board paint so my daughter could draw on it.
In my trillium I replaced it with thin plywood that matched my cabinet doors (all birch) which were just polyurethaned.
There seem to be many options!
Marjie
Rarebird is offline   Reply With Quote
Old 04-15-2011, 09:51 PM   #12
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
mine has the same Arborite that was used to redo the counter top. looks nice
Scott S. is offline   Reply With Quote
Old 04-16-2011, 12:12 AM   #13
Herb Sutton's Avatar
Trailer: 2002 Casita 17 ft Spirit Deluxe
Use a lexan panel with a road map or picture behind it.
Herb Sutton is offline   Reply With Quote
Old 04-21-2011, 05:03 PM   #14
I used an old tin ceiling tile. Rattle can it black cut it to size and slipped it in, looks great.
Wayne
Wayne Dirkson is offline   Reply With Quote
fridge
Replace weatherstripping Jane K Problem Solving | Owners Helping Owners 5 09-10-2015 12:48 PM
Replace door glass in Compact Jr Dana T Problem Solving | Owners Helping Owners 4 05-20-2009 06:35 PM
Need to replace door window scamp 83 - where and how? KarinP Problem Solving | Owners Helping Owners 7 04-20-2009 06:21 PM
Do I Replace converter or Not? Chris and Ame Care and Feeding of Molded Fiberglass Trailers 14 07-27-2007 08:13 PM
Dometic fridge front panel Legacy Posts Problem Solving | Owners Helping Owners 5 05-06-2003 10:04 PM
