what's the lightest way to make my bed where the dinette is stronger? - Page 2 - Fiberglass RV
Old 05-04-2013, 04:02 PM   #15
As I mentioned, IKEA sells many, many, many of their bed slat sets world wide (including the three sets I have) and, if they didn't hold up (I think that they are Birch) they would have dropped them by now. When all pushed together the fabric webbing will keep them from creaking and you can save your table for selling time.
Old 05-04-2013, 04:14 PM   #16
Originally Posted by Donna D. View Post
Or, maybe purchase a package of silicone "buttons" that are used on glasstop tables.
DONNA, DONNA, DONNA. Not silicone
Old 05-04-2013, 04:21 PM   #17
Ed Harris's Avatar
If the bed is made as the factory intended then the table rests on the 2 side seats to bridge the gap and make the back one complete platform and thus the bed.
I have been in a lot of these and not experienced creaking or twisting but I would think the plywood laid across all 3 parts side to side would strengthen the whole thing up too.
As I said before the plywood weight is just not a big deal at all here,if you think it will work just try it.
On the other hand if you try too much before really diagnosing the problem it may not get better so Donnas idea is also likely worth trying.....as usual!
There is also the likelihood that it simply creaks as the 3 surfaces sort of slide into each other and unless you create a single solid panel under the mattress it might keep doing this,either way I can not imagine that it is hurting anything so I would make sure the table is sitting in the channel made for it and not worry about it.
Old 05-04-2013, 04:38 PM   #18
Raz
Raz's Avatar
Vermont
I used 1/2" AC plywood with a pine stiffener. Might weigh 10 lbs? But the bed is much smaller. Raz
Old 05-04-2013, 04:57 PM   #19
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Exactly what I did, too.
Old 05-04-2013, 04:57 PM   #20
lpk49's Avatar
Trailer: 2007 casita freedom deluxe-2013 tacoma
New Hampshire
i think i'm too heavy...and i havent been able to fix that...
lpk49 is offline   Reply With Quote
Old 05-04-2013, 05:03 PM   #21
lpk49's Avatar
New Hampshire
ahhhhh. this describes it. i'm not good with words. when it has to do with construction.
"If the bed is made as the factory intended then the table rests on the 2 side seats to bridge the gap and make the back one complete platform and thus the bed.
I have been in a lot of these and not experienced creaking or twisting but I would think the plywood laid across all 3 parts side to side would strengthen the whole thing up too."
i'm glad to see 1/2 inch works. i was thinking i'd have to go bigger. that will be easier. i'm not sure what "stiffener" means tho.
Old 05-04-2013, 05:22 PM   #22
BUTTONS, not caulk Glenn! The only other choices are cork or felt. My bed creaked in one corner evertime I turned over. The buttons cured that and cheap too.... just like me
Old 05-04-2013, 06:11 PM   #23
theresa p's Avatar
New Brunswick
i'm with donna. we have used the felt pieces that are adhesive meant to go on the bottom of chair legs or other furniture. work great.
and it's not cheap. we're thrifty.
Old 05-04-2013, 06:16 PM   #24
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I left the table top but took the leg off. Then I used 3/8 inch plywood across the whole length (width of trailer) and put the mattress over that. No creaks. The table top offer strength but the plywood keeps the full weight from ever being just on the table. (I was concerned about that, too.)
Old 05-04-2013, 06:17 PM   #25
cpaharley2008's Avatar
Stiffner is a piece of wood trim, around the edges underneath which will keep it stiff. A piece of 1x2 moulding as in the picture will strengthen the edges where one normally will put a knee or sit and place more concentrated weight in an area.
Or maybe a shot of whiskey or the prescription kind!!
Old 05-04-2013, 08:41 PM   #26
Mike Magee's Avatar
Trailer: Li'l Hauley
If the table is not bowing in the middle but is staying flat and straight, it probably is fine. But I can understand the desire to have peace of mind that the thing is not going to collapse suddenly. Plywood is hard to beat for its good strength and low price. Do not use OSB board or particle board, though, they do not have the same strength.
How to prepare Tofu
Step 2: grill some meat
Old 06-02-2013, 08:42 PM   #27
MsRubyLu-Kathy's Avatar
Trailer: 1987 Bigfoot 13'
If it creaks and moans, is it possible it's something as simple as rubbing against the fiberglass cabinetry? A cheap fix would be to line the bottom edge of the board with Dollar Store no-creep shelving liner. ...
I just tried the shelf liner on mine and no more creaks nary a one over two nights camping. Thanks Donna
MsRubyLu-Kathy is offline   Reply With Quote
Old 06-02-2013, 09:24 PM   #28
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I ran some foam tape down mine, although for a different reason. It doesn't creak, though.
What do you do to make the bed more comfortable? Stacy Crotser Care and Feeding of Molded Fiberglass Trailers 18 04-14-2013 09:31 PM
casita 17 - to make dinette into permanent bed??? lpk49 Modifications, Alterations and Updates 0 04-09-2013 09:29 AM
Make your own bed ideas Panoz77 Modifications, Alterations and Updates 23 03-17-2012 07:37 PM
HELP! Can I even make a front dinette? Vickie B. Problem Solving | Owners Helping Owners 21 04-10-2011 04:28 PM
How to make my bed more comfortable.... mcnick Problem Solving | Owners Helping Owners 12 11-27-2007 06:17 AM
