Which glue to use for ceiling styrofoam? - Fiberglass RV
Old 08-02-2019, 10:33 AM   #1
Trailer: bigfoot
SK
Midway through reno of '81 Bigfoot B17 and am wondering which glue would be best to use when putting the styrofoam back on the ceiling. Any ideas? Thanks
g4fishing is offline   Reply With Quote
Old 08-02-2019, 10:38 AM   #2
OCJohn's Avatar
Trailer: Hymer
You might check here: www.thistothat.com
OCJohn is offline   Reply With Quote
Old 08-02-2019, 03:09 PM   #3
Trailer: Escape 5.0 TA
Adhesive
So is the insulation extruded polystyrene or expanded polystyrene and what exactly is fiberglass?
starbrightsteve is offline   Reply With Quote
Old 08-02-2019, 06:45 PM   #4
We used PL Foamboard adhesive when we did our ceiling restoration. Readily available at hardware stores.
Shawn B. is offline   Reply With Quote
Old 08-02-2019, 07:29 PM   #5
the vintage ones were all done with standard yellow contact cement. It has the right heat resistant rating. Much easier to brush on the liquid than to use spray adhesive inside of a completed travel trailer. Follow the directions regarding how long to wait before you contact the pieces together. Even after all these years it still works and performs with good longevity and strength for this kind of situation. It is what I used to put the foam insulation onto the fiberglass ceiling of my Campster renovation. You can buy it at any hardware store.
Old 08-05-2019, 04:12 PM   #6
Trailer: bigfoot
SK
Thanks for the help
Thank you everyone for the replies. I'm going to give the yellow contact cement a try.
Old 08-08-2019, 06:45 PM   #7
I repaired a few small spots on my Trillium elephant skin using a hot glue gun. Fast and simple.
Paul
paul paquette is offline   Reply With Quote
Old 08-09-2019, 06:17 AM   #8
Paul
Standard hot glue gun sticks are not appropriate for the temperatures that can happen to a ceiling in the hot sun. The adhesive will soften under those conditions.
The exception being a specialized very high temperature hot glue gun that uses Pur which are polyurethane glue sticks. That specialized glue develops cross linked boding that increase over the next few weeks as it cures. The glue comes in metal cartridges that insert into the special gun. It is fairly expensive to use as well so you would only find it in woodworking stores or online specialty suppliers. I got mine from Rockler quite a few years ago but they no longer sell them or the cartridges. A very high heat hot melt is not an appropriate glue for foam. It does adhere very well to the interior side of the trailers and to wood as well. I used the fast setting version to tack the wood furring strips I applied inside my trailer to hold them in place while the epoxy cured.
https://www.hotmelt.com/blogs/blog/p...e-pur-hot-melt
Old 08-14-2019, 11:02 AM   #9
PL premium for foam will do the job
Peter10 is offline   Reply With Quote
Old 08-14-2019, 05:00 PM   #10
Trailer: Roamer TC
I have had miserable experience with the blue foam board adhesive that comes in a caulk tube. This was in existence back when liquid nails would dissolve foam, now LN is good.
I use Liquid Nails Extreme and it works great. I am not sure about temp, but imagine the roof temps are fine. I have used it on ceilings/under roofs with no issues.
Roamer is offline   Reply With Quote
What glue is the best to glue the fabric on the sealing. Falicea Problem Solving | Owners Helping Owners 11 10-31-2017 09:22 PM
Which Casita would be best for heavy computer use? whoot General Chat 30 04-27-2015 01:54 PM
Which color Rust-Oleum Marine Topside paint to use for Scamp greendrew Modifications, Alterations and Updates 2 11-20-2014 07:55 PM
What glue to use on AC cover? Kevin K Problem Solving | Owners Helping Owners 5 04-12-2014 06:58 PM
which caulk to use Isaac Problem Solving | Owners Helping Owners 1 06-06-2007 11:31 PM
