Who has "replaced the water heater with a outdoor camp shower unit? - Page 2 - Fiberglass RV
Old 08-22-2013, 06:24 AM   #15
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Brian B-P View Post
Shawn, you asked a question and I answered. I didn't know there were qualifications required of those permitted to answer. I'll stop responding, and I assume everyone else should, too.
Sometimes people are merely looking for someone to agree with them, not really seeking guidance. True of most forums I subscribe to. A human foible, I fear.
Old 08-22-2013, 06:32 AM   #16
ShawnKK's Avatar
A 2 room. Now that is kool. One room to shower in and the other to change and or use the crapper. Great stuff you have going on there. I am trying to gear up for cooler weather, too hot to do much camping here now. We were talking about that last weekend. Florida is too D@m hot in the summer time.
ShawnKK is offline   Reply With Quote
Old 08-22-2013, 05:18 PM   #17
Trailer: Fiber Stream
Originally Posted by rockead rob View Post
I bought an Eccoterm 5L off of Amazon based on its reviews. I am in the process of welding a post to my U-Haul Trailer Tongue which I will mount my propane tank on one side and Propane Heater on the other. The heater will provide hot water to the sink and the newly added outdoor shower. I have not actually used the heater yet but am anxious to see how my project turns out.
Me too! This looks do-able for my Compact Jr. rebuild. Like you I plan to carry it disconnected in storage on the road, and set it up at the campsite.
Old 08-22-2013, 08:49 PM   #18
Jeff Richardson's Avatar
Trailer: 1977 13-foot Scamp
I've been using an Eccotemp 5L instant hot water heater mounted on the tongue of my 1977 13-foot Scamp for over a year now. It works great!
The inspiration was when I went to the vintage trailer rally at Roslyn, WA last year. There are no shower facilities at the city park where we camp. I had to carry a 5 gallon bucket of water from one end of the field to the middle where my trailer was. I heated the water on the stove for a sponge bath. This year I was better prepared.
I have a 6 gallon Igloo brand tank that is secured to an aluminum hand truck I bought at Office Depot for around $45. It is rated at 250 lbs. It carries 48 lbs. of water across the field easily. I was again in the middle of the field this year.
On the back side of the square steel tubing I bolted to the tongue of the trailer I have a 12 volt Flojet pump that I bought at Camping World. I believe it is Model 3526-144.
The hot water then goes into the city water inlet. Inside I put a tee fitting so water can go up to the sink faucet or straight to a ball valve with a 1/2" NPT pipe on it where I can attach the shower wand.
I stand in a 28-inch diameter plastic pan that is made to go under a hot water heater tank. It is only 2.5-inches deep. I can rinse off without a shower curtain by crouching down and carefully keeping the wand close to my body. I may have a little puddle or light spray around the pan but most of it stays in the pan.
I've been letting the water run out of the pan onto the grass or into a 12 gallon gray water tote just outside the door. To get the water to drain I have to lift the side of the pan opposite the drain tube to get the water to flow out the door.
After showering two nights last weekend in the trailer I went to a Coastal Farm and Ranch Supply store 2 miles from home and bought a 40 gallon oval plastic tub to replace the hot water heater drain pan. It will work so much better than the shallow pan I've been using.
The 40 gallon tub is 39 inches long by 29 inches wide by 13 inches high. It literally is a bath tub. I definitely won't need a shower curtain with this. I will be able to sit inside it and rinse the upper body. I will then stand up and rinse the lower half.
Tomorrow I will assemble a 1/2-inch pvc pipe which will connect to a 12 volt marine bilge pump so I can pump water out of the bath tub up into the sink where it will flow into the 21 gallon gray water tank under my Scamp. I bought that gray water tank from Scamp. It is the one they use.
Because the hot water has to go through a 10-foot hose to the city water inlet, I go through a lot of cold water before it gets hot. I do get steaming hot water eventually. I it really speeds up washing the few dishes I used in preparing a meal.
This winter I will move the mounting for the hot water tank to a hitch-like receiver just ahead of the refrigerator vents. The 12 volt pump will be mounted inside under the front bench by the refrigerator with fittings alongside the heater mount. A much shorter hose to the city water inlet should work better.
This is the only time I've had to use the 12 volt water pump. Normally I have water hook ups but not always sewer.
I'm going out this weekend and will try the bigger tub. I will post an update on how that works with photos. I also found the perfect plastic tote at Lowe's for the putting the hot water heater in and all hoses during transport. I do not leave the hot water heater mounted on the trailer when traveling.
It is very comforting to know I can have a refreshing shower anywhere I can get water. I'm looking forward to some day getting water out of a lake or stream if I have to.
The attached pictures show park in Roslyn, WA where we camped. The last picture shows the actual water flow with the 12 volt pump.
Jeff
Jeff Richardson is offline   Reply With Quote
Old 08-22-2013, 09:19 PM   #19
Trailer: 1984 13' UHaul
Louisiana
Nice! I am a little simpler. I have a Zodi Extreme. With a shower tent, I'm set.
itlives is offline   Reply With Quote
Old 08-23-2013, 11:53 AM   #20
ShawnKK's Avatar
Rob, I just found this great ideal for you in your outhouse.
Old 08-23-2013, 12:23 PM   #21
rockead rob's Avatar
Trailer: U Haul CT 13
What a great idea! We have those floating around the office. Thanks.
rockead rob is offline   Reply With Quote
Old 08-23-2013, 07:40 PM   #22
Louisiana
That is a great idea!
Old 08-23-2013, 08:19 PM   #23
If you think a CD tower solves the problem... turn it UPSIDE down otherwise the rim wicks water... don't ask me how I know
To drag the thread back to the OPs question, WHY does it have to be ONE or the other? Can't it be both, based on a particular camping need for a given trip? That's what I'm thinking....
Old 08-23-2013, 08:40 PM   #24
Trailer: In the market
Hula hoops with shower curtain(s) stretched around, hang off a tree or your awning: Splash out on an outdoor shower | Life and style | The Guardian
Bottom of the page. And it folds flat.
Seamstress is offline   Reply With Quote
Camp Chef tankless water heater anybody? brownrecluse Modifications, Alterations and Updates 16 07-06-2015 10:26 PM
For Sale: Outdoor Shower Parts Deb & Chuck Parts: Buy | Sell | Trade 2 02-14-2012 12:53 PM
Tankless Instant Shower Water Heater Lisa H. General Chat 10 06-14-2008 05:32 PM
Solar Water Heater Shower Bonnie General Chat 10 04-26-2008 03:40 PM
Tankless Instant Shower Water Heater Lisa H. Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
