Why Modern Windows - Fiberglass RV
Old 09-11-2015, 02:09 PM   #1
Trailer: Currently Shopping
Why Modern Windows
Is there an actual advantage to the rounded corners of the modern windows over the square corners of the older windows? Just curious why people update if it's not broken.
Camper Creative is offline   Reply With Quote
Old 09-11-2015, 02:29 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
If you look closely at the aluminum framing of the modern (radius) windows, note there are no corner seams to leak - the extrusion is bent into a smooth surround. Fewer placed to have water come in, as the gasketing is also seamless. Not the case with the old square ones.
Charlie Y
Old 09-11-2015, 03:31 PM   #3
Trailer: 1979 Scamp 13'
To me, there is an airflow advantage to the older style of windows, as they can open fully.
The new ones do look more stream lined and modern...
Zennifer is offline   Reply With Quote
Old 09-11-2015, 03:50 PM   #4
I believe in the older trailers (Scamp Casita Boler, ets.) the rear window didn't open the square side windows were a bit smaller. The newer with rounded corners not only have less of chance of leaking but the third window opening in rear and in the case of the Scamp an over sized roof vent you get lots of ventilation. Except when it rains. But even then the trailer is movable and can be moved to someplace where it isn't raining.
Old 09-11-2015, 04:01 PM   #5
Walk into the corner of those old style jalousie windows and you will under stand why the newer windows are nicer. I like my modern style windows on my 1986 Scamp. Living in So Cal the benefits of Jalousie windows don't apply here. If i lived in Washington or Florida maybe I would have a different opinion.
Old 09-11-2015, 05:07 PM   #6
That makes them an advantage in a new trailer, that has that openable back window...but in an old trailer with a fixed front and back window, I do think the wider open-ability of the full jalousie windows is crucial for good ventilation, and replacing them with newer windows may cut the air flow of the trailer...ymmv.
(I intend on replacing my tiny vent with a nice big one. )
Old 09-11-2015, 05:22 PM   #7
IllAnnoy
I call the old square aluminum windows Red Ryder windows because I hate to walk around a Scamp with those windows open...
Old 09-11-2015, 07:45 PM   #8
Trailer: 1992 Casita Spirit Deluxe
Virginia
The rear window in my '92 Casita is three fixed plexiglas panes. I'd love to put a jalousie in place of the center pane, and it wouldn't ever hit anybody as it would be guarded by the spare tire.
steelypip is offline   Reply With Quote
Old 09-11-2015, 08:14 PM   #9
Ian G.'s Avatar
To me there is not a single advantage to the radius windows, the Jalousie open fully allowing 100% ventilation from the opening and they can be left open when raining and water does not come in the trailer. I wish my new Escape 19' had the Jalousie windows like my Boler
Old 09-11-2015, 10:03 PM   #10
tractors1's Avatar
So change them!
Charlie Y
Old 09-12-2015, 06:12 AM   #11
I'm 100% in agreement with Ian! If there were double-pane jalousie windows available for my trailer(s) I'd have them! Anybody that walks so close to my trailer that they'd run into an open window is walking to dang close. I mean really, what they only stick out six inches or so? Pad with a pool noodle if you must.
Old 09-12-2015, 08:38 AM   #12
IllAnnoy
One clear advantage of sliders is simplicity, they don't have all the mechanical parts to wear or fail, and there are no knobs to twist. plenty of rain free ventilation with the addition of Maxxair window vents and they are actually shut when they are shut.
Old 09-12-2015, 09:35 AM   #13
Raz
Raz's Avatar
Vermont
The Hehr radius jalousies have a fixed side glass size so the larger the window, the greater the percentage that opens. When closed they will weep, that is, you get a small amount of leakage in a hard blowing rain. If the trailer is level, it goes out the weep holes. Most of the window mechanism is aluminum but some is unplated steel and requires periodic maintenance. The opening mechanisms have lots of play . The gears do not appear to be well machined. That said, I've had no problem with them. I bought my trailer because of the windows and despite my critical comments, I am very happy with them. Raz
Old 09-12-2015, 09:48 AM   #14
Trailer: Trillium Outback 2004
I tried everywhere (online) to obtain Maxxair Window Vents without success. Two companies had them listed but when I ordered they said they were out of stock and were no longer being made. Anyone else found these recently? Otherwise I'd love to have some good jalousie's.
BarbinBC is offline   Reply With Quote
windows
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 12:50 PM
Vintage Style Decals on More Modern Scamp barryra Modifications, Alterations and Updates 11 08-11-2014 08:06 PM
Jalousie Trade for Modern? David Morgan Classified Archives 13 06-23-2011 12:07 PM
Replacing the rectangle aluminum windows with modern rounded corner windows Evergreen Modifications, Alterations and Updates 16 10-29-2010 12:09 PM
