Wind baffle for water heater - Fiberglass RV
Old 12-02-2002, 03:01 PM   #1
I just installed a wind baffle on my water heater door on my Casita.
The last few outings, the water heater pilot blew out several times. Not being wealthy, I thought I'd try a wind break before springing for a re-igniter.
I fashioned the baffle from a double thickness of 6" aluminum flashing cut to 11" length. At each end I made a ½" 90º bend then 1" from that I made another 90º bend. The finished product is 8" wide by 6" high and it is 1" away from the vent screen. I put one rivet in the center to hold the two pieces together.
The first photo shows the finished baffle and the tape I used to install it. The second photo is a closeup of the baffle mounted to the door. The third is the water heater door showing the baffle in place.
I'll let you know how the tape holds.
<img src=http://www.fiberglassrv.com/board/uploads/3debd71987e9atape.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3debd6c9f3c9dbaffle.jpg/>
<img src=http://www.fiberglassrv.com/board/uploads/3debd7914419cdoor.jpg/>
Old 12-02-2002, 03:31 PM   #2
Morgan,
I think I would buzz a couple of sheet metal screws in from the inside.
The tape alone may be iffy.
When I had a stationary 28 foot stick thing, my water heater would blow out from the wind too. It funneled into my site just right, even with a cover like yours it still went out, some days several times.:sick
When I moved the trailer to Wisc. the setup was just right I guess, because it never blew out again.
Now I don't worry cause I don't have hot water in my Burro.
sniff,sniff:weep :weep :weep
Old 12-02-2002, 07:30 PM   #3
Orginally posted by pjanits
* * * * * * Morgan,
When I had a stationary 28 foot stick thing, my water heater would blow out from the wind too. It funneled into my site just right, even with a cover like yours it still went out, some days several times.:sick *
Thanks Pete,
I'll let you know how the tape works out. If it doesn't hold, I'll use rivets. I may find the aluminum is too flimsy also; it's a prototype.
Old 12-02-2002, 07:37 PM   #4
Morgan
You do nice work!;)
Old 12-02-2002, 10:40 PM   #5
Morgan
nifty idea! I like it.:)
Perhaps you could drill a couple of holes in the front big enough for a screwdriver shaft and fasten it with screws that way.
(or is that a no-no for fiberglass integrity?)
P.S. That workbench looks kinda new - did you have to buy that to hold the new mod? :E :E *just kidding!*
Old 12-03-2002, 04:23 AM   #6
Orginally posted by Suz
* * * * * * You do nice work!;)
Just not much of it. :bed
Old 12-03-2002, 04:30 AM   #7
Orginally posted by Rick
* * * * * * nifty idea! *I like it.:) *
Perhaps you could drill a couple of holes in the front big enough for a screwdriver shaft and fasten it with screws that way. *
(or is that a no-no for fiberglass integrity?) * *
P.S. That workbench looks kinda new - did you have to buy that to hold the new mod? * * * :E :E * * *just kidding!* *
Rick,
The water heater door is sheet metal. I can rivet from inside the door if need be. I just have to get small enough to fit in the compartment. :laugh
The work bench is new, I bought it to hold my outboard motor. Those top planks pivot up 90º and clamp together. It works great as a sheet metal break, too. It cost US$16 at Big Lots. :banana
Old 12-23-2002, 06:48 PM   #8
I found that Home Despot does not carry the VHB tape, I bought it at Lowe's.
Sorry for my lying ways. :hide
Old 01-01-2003, 02:45 AM   #9
An update
We took the Lazy M camping for three days starting on Boxing Day.
The 3M VHB tape I used to mount the wind baffle worked flawlessly. The water heater went out once, so the baffle may need work.
We didn't go very far, but we were off-roading some.
Old 01-01-2003, 08:33 AM   #10
went out
Morgan,
I've looked this thread over, and I can't find where you said if you were moving (the trailer, not you personally) or not when the hot water heater goes out. I read somewhere you weren't to travel with the ref on propane, so I assume the w/h shouldn't be on either. having remembered all this, I surmised you were parked in the beautiful lake spot when this w/h incident happened?
BUMMER :sad what a way to deteriorate a perfect time.
Old 01-01-2003, 10:50 AM   #11
Orginally posted by Thomas and Janifer
Morgan,
JJ Pullstrailerwithyellowescape,
Thanks for the concern, but it's not a big deal when it goes out. I just relight it. That's not so easy when the wind is blowing into the compartment, but to paraphrase an old Indian friend, I endeavor to persevere. Before the baffle, it would blow out several times a day during windy conditions.
Your surmission was correct. I always turn off the water heater when traveling. I sometimes drive with the refrigerator running on propane. One has to remember to turn it off during a refueling stop.
I surmise you're not hung over from all your New Year revelry last night. :sick
Old 01-01-2003, 02:55 PM   #12
hung over
Na! :nope I made it last night just fine. all that -partying- didn't last long. Getting ready for the big game today almost did me in though. Livingroom TV was about to blow, so bought a new one. and of course it was bigger, so had to have a new cabinet to put it on. getting all that off the pickup and set up, I'm exhausted. :zz good thing I only have to do that once every twenty years. why didn't I do that when the kids were here? :bh
water heater Sandra Lair Modifications, Alterations and Updates 16 10-09-2009 10:58 AM
Can I run my Hot Water Heater Karalyn Plumbing | Systems and Fixtures 8 06-22-2009 10:53 AM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
Water heater pjanits Problem Solving | Owners Helping Owners 4 04-11-2006 01:23 PM
Hot water Heater Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 06-30-2003 02:14 PM
