Hi Parker,
I, too, noticed your A/C mod when I read your "for sale" ad - because it looks so good, and so well designed and executed.
I have a couple of questions. These aren't specifically for my particular trailer, as I have no need for A/C, but I'm still interested, and probably other people will be too. (And you never know -- maybe I will want AC in future.)
1) When you say that this required no mods to the trailer; how did you get the AC through the window? Do you have a sliding rear window as opposed to the (also common) Plexglas window that is fixed and mounted in rubber seals? And if so, did you remove one half of it, or merely slide it open?
2) If you do have a sliding rear window (and I suspect this is the case), then can you say here what year your Scamp is? I believe that Scamp made the rear window area molds more "flat" at some point in the manufacturing process. Would be nice to know which one yours is.
I have seen the older "more round" Bolers and Scamps with sliding rear
windows, but you don't often see people retrofitting them to the Bolers or "round" Scamps. I've often wondered if the sliding rear
windows in those campers actually functioned well (due to the curvature of the shell in that area).
Thanks for posting this mod
Raya
PS: Does anyone know exactly when Scamp "flattened" the rear window areas of their 13-footers? (I don't know if the 16's were affected or how their back window is designed.)
