Window Awnings - Fiberglass RV
Old 01-18-2007, 04:27 PM   #1
kconley's Avatar
Trailer: 95 Casita Spirit Deluxe 16 ft
If we don't soon leave for Florida, I'm going to apply to Casita as a designer... Our 95 has louver windows, but have read a lot of peoples problems with rain coming in new sliding windows. I'm working on a late night project while wife is away.. A set of Awnings for the windows not covered by the large Awning...
It's only in the early stages, but the only thing that will be attached to the camper is a thin track above window. When you want to set it up, slide the Awning in the track & stick the suction cups to the side & it's up !!!! No rain in the window & you don't need to spend $$ on the plastic louvers that block most of the window.... ANY THOUGHTS ON THIS MOD ?? I made this 1 from a old ATT vinyl poster & fiberglass rods from kites. It could be made from sunbrella material or anything to match the big Awning... KENN
kconley is offline   Reply With Quote
Old 01-18-2007, 05:54 PM   #2
Trailer: 86 Burro 17 ft Widebody
Kenn,
Looks like a good idea to me. I have used fiberglass rods for some projects and you can get them at the local hardware stores as driveway markers, generally 4 footers and 6 footers.
Rick
Rick F. D. is offline   Reply With Quote
Old 01-18-2007, 06:42 PM   #3
I think anything you do to your trailer that makes it more comfortable for you...is great!
My only concern would be how much light a solid fabric would block. If it's gray and rainy, it's already "dark" outside and I'm one that needs all the light I can get. It would require more $$ and maybe some sewing, but you can purchase heavy clear vinyl to use as inserts in the awning to let more light in.
Old 01-18-2007, 07:13 PM   #4
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
But, But...
If you want shade, like we usually do, this would be perfect.
Old 01-18-2007, 07:42 PM   #5
Nita F.'s Avatar
Kenn,
We don't have or want an awning, but our Scamp 5th wheel came with a rail attached. I've wanted some protection from rain over the door and your idea just might work. Thank you for sharing.
Nita
Nita F. is offline   Reply With Quote
Old 01-18-2007, 08:30 PM   #6
But, But...
Absolutely! I was commenting on this:
Our 95 has louver windows, but have read alot of peoples problems with rain coming in new sliding windows.
Old 01-20-2007, 03:30 AM   #7
kconley's Avatar
Donna has given a great idea CLEAR AWNINGS . This first 1 was just made with stuff i had laying around to see if it worked. But I may try to make 1 out of clear vinyl, could use the stuff the make furniture slip covers out of.. THANKS FOR ALL THE INPUT
Old 01-20-2007, 12:19 PM   #8
Trailer: Casita 13 ft
Ken, this is awesome! I could see someone doing this in a beautiful fabric or a colorful vinyl for all their windows - talk about looking homey & cute. I want to do it but alas .... hubby and I are not handy people (darn it) .
Somebody please do this and take pics - adorable! This mod would really make your trailer stand out!
Good job, Ken. I bet you inspire lots of folks!
Patty
Patty C. is offline   Reply With Quote
Old 01-20-2007, 01:26 PM   #9
Suz
Suz's Avatar
That's exactly what I had in mind for my '89s kitchen window. It looks terrific! I used PVC for the frame over my A/C in the back window. Those fiberglass rods seem to be a great idea for the small one I want.
Suz is offline   Reply With Quote
Old 01-20-2007, 08:53 PM   #10
Gina D.'s Avatar
West Coast USA
This is simple amd very clever. Good job!
How do you think it will hold up in the wind tho?
Old 01-21-2007, 05:10 AM   #11
kconley's Avatar
Iguess it would depend on how strong the wind is & how well the suction cup holds. This is only a mod in the making like I said I used stuff on hand... I was pleased it came out so well. kenn
Old 01-21-2007, 08:31 AM   #12
Suz
Suz's Avatar
Gina, I thought about using a tension strap on mine that hooked underneath the belly band. That wouldn't work on your Burro, but you might be able to rig something that could be secured to the lower part of the window frame.
Old 01-21-2007, 09:10 AM   #13
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I like this idea too.
You could interrupt the pocket for the bottom rod for an inch or so, stitch Velcro onto a 1" strap, put an adjustable plastic thingy to snug up the length and a plastic hook for the end by the belly band. The strap would be removable when it wasn't needed. Or, you could just buy a spool of bungee cord material and tie it to the rod and the plastic hook. It would degrade over the years but would be easily replaced.
Anyone have a web url for the track it would slide into? Knowing the channel width would be important in determining the rod and fabric or vinyl thickness to use.
I suppose UV resistant thread would be a nice touch also. I don't know about sewing vinyl on a home machine. Shouldn't be too tough if you don't use too thick of vinyl or fabric.
West Marine sells clear and tinted vinyl with UV inhibitors:
West Marine Vinyl
UV thread. I don't know anything about thread sizes, but this is probably pretty heavy for a home machine.
West Marine UV Thread
I wonder if an adhesive wouldn't do the job?
Vinyl Adhesive with UV resistance
Quando omni flunkus, moritati
Old 01-21-2007, 10:46 AM   #14
Gina D.'s Avatar
West Coast USA
I am gonna get some of that goop for my seats!
Thanks!
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
Awnings? Jonathan S. Care and Feeding of Molded Fiberglass Trailers 8 06-01-2009 07:52 PM
O.K., Here I go again with AWNINGS. Mike Montville Problem Solving | Owners Helping Owners 40 08-31-2008 07:03 PM
Awnings (Again) Toni M T Problem Solving | Owners Helping Owners 0 06-26-2008 07:35 PM
Awnings Sharon Herman General Chat 18 03-15-2006 05:31 AM
