window replacement - Fiberglass RV
Old 11-11-2013, 12:11 PM   #1
Trailer: boler 1974
Manitoba
window replacement
We have a 1974 boler and bought frosted replacement windows from scamp for the door and over the stove. Have no idea how these two pieces fit into the boler. Please help
DebbieB is offline   Reply With Quote
Old 11-11-2013, 02:18 PM   #2
The window goes into the opening in the trailer wall from the outside. The "clamp ring" goes on the inside of the wall, screws go through it into a slot in the window frame to hold the window in place. On our Uhaul, when I installed a Scamp window I had to put the clamp ring on backwards because apparently scamp has a thick wall whereas Uhaul has a thin wall. Window and clamp ring have to fit together so when the screws are tightened they draw the window against the outer wall of the trailer. If Scamp sent the foam sticky tape with the windows I strongly suggest that you not use it as it may prevent the window from drawing in tight and sealing good. Tried it on my windows and they leaked. Pulled them back out, removed the foam tape, put them back in with the black butyl tape, no more leaks.
Old 11-11-2013, 04:32 PM   #3
Trailer: 77 Scamp 13
Butyl tape rules for setting windows or anything else into fiberglass. So plus one on what mary and bog said about that.
Old 11-12-2013, 01:58 PM   #4
Trailer: boler 1974
Manitoba
The window and clamp ring do not fit together on the boler door as the door has a wooden core. Any suggestions?
Old 11-12-2013, 04:23 PM   #5
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
Hi Deb, I called Mike and gave him some suggestions and instructions. Also gave him my phone number in case he has more questions.
Rick
Rick Mooyman is offline   Reply With Quote
Old 11-12-2013, 05:11 PM   #6
Modify the clamp ring or put it on backwards. Or maybe make your own clamp ring out of flat aluminum.
Old 11-24-2013, 04:45 PM   #7
Trailer: boler 1974
Manitoba
The windows are now in the boler and it worked out well. Thanks everybody for your suggestions, especially Rick and Luke who guided us through the process and offered moral support over the phone. Mike and Deb
Burro Window Replacement Shane O Problem Solving | Owners Helping Owners 3 09-12-2010 09:27 AM
window replacement matt scott Care and Feeding of Molded Fiberglass Trailers 5 11-11-2009 11:03 AM
Front window replacement Frank Bland Care and Feeding of Molded Fiberglass Trailers 1 05-02-2008 08:08 AM
WINDOW REPLACEMENT dennis and michele Classified Archives 1 11-18-2007 06:00 AM
Window replacement advice? Legacy Posts Modifications, Alterations and Updates 7 02-13-2003 05:04 PM
