Winterizing 1975 Honey Boler - 13ft - Fiberglass RV
Old 08-09-2018, 05:58 PM   #1
Trailer: 1975 Honey Boler
BC
Hey there!
I plan on living in my trailer for this winter but need to winterize the place as it will be in the mountains of BC and very cold. I am wondering if anyone has tips on how to modify the trailer? How would you recommend insulating? I am hoping to install a tiny wood stove but am worried about drilling a hole into the fiberglass, and also about how the stove will withstand bumpy roads. has anyone had experience with this? Is there another form of heating I could install instead?
I am also wondering what fridge you would recommend for this brand of trailer as I only have the ice cooler but would like something run by the propane.
Thank you!
cmarti14 is offline   Reply With Quote
Old 08-09-2018, 08:14 PM   #2
ShelbyM's Avatar
Trailer: Casita SD
Do you have a Plan B? There are a number of propane heaters available but there is no way to add significant insulation. You may be warm only while the heater is running. You probably won't be able to keep your water system from freezing, will need to drain it. Condensation is another uncomfortable issue. Maybe stack some bales of hay around the perimeter to keep the wind out.
Old 08-09-2018, 08:42 PM   #3
Sounds like the great outdoors would be your freezer and the inside, your fridge.
Old 08-09-2018, 08:57 PM   #4
You might want to reconsider your option for living space. You are going to be miserableeven with a wood stove. Trying to insulate a Boler is going to be difficult because of all the curves in it. You would have to build a wood frame four inches inside of the Boler shell to get enough thickness of insulation to stay warm.
The other factor is with a tiny wood stove you will have to keep getting up at night to put more wood into the fire to keep warm enough. If you don't then your ceiling and walls will become coated with thick frost and when it melts in the morning when you fire up the stove the water from the ceiling will be raining down on you and the water on the walls will be running down onto the floor. Of course there is the issue of where you will obtain and store the firewood. You can' just go out and gather it from the woods when you need it. Wood has to be seasoned and dried for it to be of any use for heating.
As to using propane for heat, your on-board tank(s) will not be able to keep up with the demand for full time heat. You will be constantly running out of propane which means you will be spending a LOT of money to keep warm.
As to the refrigerator, if it is that cold outside you don't need one during the winter time.
Old 08-09-2018, 09:07 PM   #5
traffensperger's Avatar
Trailer: Burro 13' trailer
friends my to Thanks F g cuddle
traffensperger is offline   Reply With Quote
boler
New Boler Owner 1975 Honey BrianT Hi, I am.... 4 02-15-2017 05:35 PM
ON | 1975 13' Honey Bee Travel Trailer by Boler elgin Classified Archives 13 05-06-2012 07:02 PM
EEE Boler/Honey Rick M General Chat 1 05-20-2009 08:30 PM
New Owners of a 1973 Boler Triple E Honey Ash and Colleen Care and Feeding of Molded Fiberglass Trailers 11 05-06-2009 09:55 PM
1975 13 ft HONEY BOLER FOR SALE CarolD Classified Archives 0 10-14-2008 07:13 PM
