Winterizing and Waterheater Bypass Mod - Fiberglass RV
Old 07-01-2013, 05:29 PM   #1
papa-t's Avatar
Glade Valley, North Carolina
Since I finished installing a second fresh water tank under the seat storage, I decided to install a winterizing hose and hotwater tank bypass; so it will be easier when it comes time to winterize the Scamp with RV Antifreeze. The hot water tank already had one shut off valve on the lower 1/2" pex pipe. So, I added a second shut off valve on the upper 1/2" pex pipe, then installed a bypass between the two pipes using two brass tee's with another shut off valve in the middle. When time to winterize I can close the upper and lower vlaves and open the center valve; keeping the RV Antifreeze from going into the water heater, allowing it to bypass the water heater and still access all other hot water water lines.
This is the way most bigger rv's set up the water heater bypass for winterizing. Then next to the fresh water tank I installed a 1/2" plastic Spiral Tee fitting in the hose between the fresh water tank and the water pump. I installed a shut off valve on the water tank side of the plastic T -valve; to close off the fresh water tank side when adding RV Antifreeze.
Then I added a 5' clear hose with a shut off valve on the Spiral Tee fitting to draw the RV Antifreeze into the pipes with the water pump.
So, when it's time for winter and I want to winterize. I (1) close upper and lower water tank valves. (2) Open middle water tank bypass valve. (3) Close valve between Spiral Tee and fresh water tank. (4) Open valve to Antifreeze clear hose; put clear hose into a gallon jug of RV Antifreeze. (5) Turn on water pump. (6) Open kitchen and shower hot and cold falcets until pink antifreeze comes out. Flush toliet until pink antifreeze comes out. Always allowing pink anitifreeze to drain into sink and shower drains. (7) Last of all drain water heater.
Winterizing the unit will take approximately one gallon of RV Antifreeze and take less then ten minutes to do.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 07-01-2013, 06:50 PM   #2
cpaharley2008's Avatar
Leave it hooked up and you can then use your toilet while winter camping.
Jim
Never in doubt, often wrong
Old 07-01-2013, 07:08 PM   #3
papa-t's Avatar
This doesn't put hot water to the toilet. Sorry I don't understand.
Old 07-01-2013, 07:27 PM   #4
leave the tube in a gallon container and each flush you will pull more antifreeze thru your system to flush with.
Jim
Old 07-02-2013, 08:19 AM   #5
papa-t's Avatar
That would make for an expensive camping trip.
Old 07-02-2013, 10:17 AM   #6
Ted you will be happy you did the by pass system. My hot water tank has a by pass and I use it not only in the winter for winterizing. I will use it if dry camping and I need to prefill by tanks but I dont want to pull with the extra weight of both tanks being filled.
Or if I am on the road and have water hook ups and only staying a night I also use the bypass as I cant be bothered to fill up and start up the hot water tank for just a few dishes (use the kettle instead for hot water) and then have to drain out the tank in the morning so as to not be hauling around water.
Old 07-02-2013, 03:36 PM   #7
papa-t's Avatar
I had this on my larger 5er's in the past. Somethings you just can't do without. Or don't want to. LOL
Old 08-26-2014, 04:09 PM   #8
Trailer: Casita Patriot '13
Connecticut
I hear ya. I ordered the Camco winterizing input valve. It comes thursday. I already have hot water bypass so, I'll slip this in ahead of that and leave it there.
I really don't like the idea of the pink stuff in my water tank, or draining 2 more gallons of it the hard way.
Fingers crossed. Thanks for the great pics and explanations.
jazzjunkysue is offline   Reply With Quote
Water heater bypass Chris Z Plumbing | Systems and Fixtures 24 07-15-2016 08:01 PM
Camco 35953 water heater bypass kit ThomasE Modifications, Alterations and Updates 11 08-27-2015 07:16 AM
Battery bypass switch HappyFamily Care and Feeding of Molded Fiberglass Trailers 18 06-03-2012 09:34 AM
An antifreeze pump mod for winterizing the black tank cpaharley2008 Modifications, Alterations and Updates 1 01-13-2011 12:46 PM
Where do I find the water bypass switch? Karalyn Plumbing | Systems and Fixtures 9 10-19-2006 01:30 PM
