Wiring a Vent Fan in a Scamp - Fiberglass RV
Old 08-04-2012, 03:49 PM   #1
Trailer: Scamp 16'
Indiana
I'm thinking about installing a vent fan in my Scamp 16 std. I'm wondering about the best way to route the 12 volt wire. Can I tap into 12 Volts at the light above the dinette? How do you run wire under the fur to the vent opening. Any and all suggestions are appreciated,
Smiles, Tom
FlyboyTJ is offline   Reply With Quote
Old 08-04-2012, 05:51 PM   #2
Robert Johans's Avatar
Trailer: Nest Caravans
Tom, here are a few thoughts:
For power, you can tap into the 12V light above your dinette, ONLY if you can be certain not to overload that particular circuit.
A long, stiff wire can be pushed and cajoled UNDER the rat fur and reflectix insulation along the shell from your vent location to your power source. Hook on to your new power supply wires (18ga lamp wire works great for this app) and pull through.
As an alternative, you could cut a straight line through the rat fur and reflectix insulation, push your power supply wires under the materials and re-glue the materials to the shell. If you don't like the "scar" you could cover that seam the same way Scamp covers theirs.
Old 08-04-2012, 06:57 PM   #3
Perry J's Avatar
Trailer: 16' Casita
I added a Fantastic Fan over the table area in 16 SD so I could have a nice breeze on hot nights.
After I cut the hole for the fan I ran a coat hanger through the insulation to the Cabinet over the stove.
I ran wires down to the area behind the refer and used the 12v supply for the refer.
I also added a 12v outlet on the end of the same cabinet for my TV/VCR hookup while I was running the wires.
I used lamp cord for that short run because it does not show under the Rat Fur.
I hope this helps.
John
Adding Wiring for a Fantastic Fan susan s. Problem Solving | Owners Helping Owners 11 06-26-2010 09:47 AM
wiring overhead fan into light cyndi H Problem Solving | Owners Helping Owners 7 07-01-2009 06:38 AM
wiring a switch for the frig fan Brenda Ferrell Problem Solving | Owners Helping Owners 6 07-03-2008 04:18 PM
Replace roof vent on Scamp with fan? Conrad S. Care and Feeding of Molded Fiberglass Trailers 2 05-13-2008 06:45 PM
Replacing Scamp Ceiling Vent With Fan Parker Buckley Modifications, Alterations and Updates 6 02-29-2008 02:08 PM
