Wiring help needed - Fiberglass RV
Old 10-06-2012, 04:03 PM   #1
Trailer: Escape Trailers
Massachusetts
Wiring help needed
I will be attaching two 40-watt solar panels and running them through a 15 amp controller. I'm installing a monitor for which the negative will be wired through a shunt to the battery. When wiring the controller, do I connect the negative to the shunt or directly to the battery? Should I include fuses or breakers in either connection and if so, where?
Thanks in advance for your help,
David
Stretcher is offline   Reply With Quote
Old 10-07-2012, 02:07 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I think that it depends on what the monitor is designed to measure. Typically a shunt is used to facilitate an ammeter. Does this monitor calculate total input and output from the battery?
I'd at a minimum have a fuse or circuit breaker at the battery positive to protect the wires leading from the battery.
David
Old 10-07-2012, 02:40 PM   #3
Massachusetts
reply to Thomas G
Yes, it does measure input and output. Tri-metric TR 2025RV
What size?
Thanks,
David
Old 10-07-2012, 02:48 PM   #4
Thomas G.'s Avatar
What size?
Thanks,
David
OK, here is the installation PDF - http://www.bogartengineering.com/sit...ctions9-12.pdf
It looks like it hooks between the battery negative and the common ground connection.
The fuse must be small enough to protect the wire leading from the battery, but large enough to not blow under normal usage. What gauge wire leads from the battery positive terminal?
Old 10-07-2012, 05:40 PM   #5
Massachusetts
Thanks Tom!
Old 10-07-2012, 10:01 PM   #6
Trailer: Trillium Outback - 2004
One thing to mention, ensure your wire gauge from the battery terminal to the shunt is large enough (and short) in case you have multiple connections on the non-battery side of the shunt. Mine works great, one of the best things I've added is my TriMetric meter.
Where we’re going, we don’t need a plug-in.
multi-task is offline   Reply With Quote
Wiring advice needed ScamperCamper Electrical | Charging, Systems, Solar and Generators 2 07-25-2012 07:28 PM
Wiring Diagram for 120v 30amp Burro entrance panel needed megatrack Problem Solving | Owners Helping Owners 1 03-27-2012 07:14 PM
Trillium 1300 wiring diagram needed. William Neufeld Problem Solving | Owners Helping Owners 1 07-08-2008 12:07 PM
Scamp to Subaru trailer wiring - help needed Mikeny Problem Solving | Owners Helping Owners 7 07-27-2007 05:16 AM
Brake Control Wiring Help Needed Gail Shook Problem Solving | Owners Helping Owners 8 06-07-2007 06:02 AM
