I will be attaching two 40-watt
solar panels and running them through a 15 amp controller. I'm installing a monitor for which the negative will be wired through a shunt to the
battery. When wiring the controller, do I connect the negative to the shunt or directly to the
battery? Should I include fuses or breakers in either connection and if so, where?
Thanks in advance for your help,
David
