WTK ideas for new rear bumper on Scamp - Fiberglass RV
Old 06-23-2014, 02:32 PM   #1
Timber Wolf's Avatar
North Florida
I have all the stuff gathered up to build my rear mounted receiver hitch for my Scamp so I can mount a bike rack back there. Yes I know all the issues with a bike rack on the back of a trailer but after considering all the options I still think it is the best way for me to go. That said, I have not gone forward with the build as I also want to someday maybe build a new rear bumper and it affects how I will build the hitch. The angle iron bumper on the Scamp is pretty skimpy, and a bumper that could also hold some poles or the stinky slinky would be nice. I am thinking thin wall 4” like other trailers, but is there something else out there? Ideas?
Old 06-23-2014, 04:33 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
I'd go 1/8th inch box tubing in a 5 inch size - big enough to hold your stinky with the end fittings on. Also thick enough to get a good weld penetration that would hold your rack.
Plus you can get 5 inch square plastic fence post caps to close off the ends.
Charlie Y
Charlie Y
Old 06-25-2014, 02:22 AM   #3
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I'm going to cut it off and put a '57 chevy pickup bumper on, fits the curve perfectly. Putting it in its normal place, just set it on the tire to look.
Name:	ImageUploadedByFiberglass RV1403684544.262508.jpg
Old 06-25-2014, 05:48 AM   #4
North Florida
I don't know, it looks pretty good up there on the tire. I actually have a 1957 Chevy truck. But it is a 2 ton Mobile Home Toter and the rear bumper is a piece of angle iron just like the Scamp's. I just happen to have a rear bumper I was saving for my 1968 Chevy pickup though.
Old 06-25-2014, 07:08 AM   #5
Charlie Y
At about 50 lbs., isn't that heavy tube adding a lot of unnecessary weight to something that isn't all that good an idea in the first place?
Regular 4" square tube bumpers weight about 18 lbs.
Old 06-25-2014, 07:26 AM   #6
North Florida
And it seems a little massive looking to me also. I am going to have enough weight back there with the bike racks and bike(s). I may never actually get around to building a new bumper, I just would like to have a plan so the new rear hitch is not in the way of this maybe, possibly, someday project bumper. Come to think of it, I may have just the right piece of 4" square in the junque pile. Or as my daughter calls it, the "treasure trove".
Old 06-25-2014, 08:40 AM   #7
IllAnnoy
Here's what it might look like if you make a thin walled square tube bumper. Mine has a bumper guard which I made from unistrut and the feet from an old weight bench.
The square tube is simply welded to the original bumper, then covered with black rubber runner.
If you add a receiver, you must add an additional crossmember to the frame and weld the receiver to both the new crossmember and the bumper.
Due to the addition of the square tubing bumper, your bike rack will even more easily clear the spare tire.
This bumper assembly weighs eleven pounds complete and cost me less than the price of the end plugs.
Old 06-25-2014, 09:29 AM   #8
Attachment 72939
LOL Jared when at first look without reading your explanation I thought perhaps you were intending to turn your scamp into a bumper car
Timber Wolf, if your worried about adding the extra weight at the extreme end of the scamp re the bike rack etc, you could add a PVC square fence post with caps just ahead of your grey water tank for holding poles or the slinky hose and fittings etc Its still weight behind the axle but closer to it & not much regardless. I have found that set up works well for me and not had clearance issues even though I do travel the back roads (gravel) fairly often.
Trillium Rear Bumper Failure indigodave Modifications, Alterations and Updates 5 09-07-2013 02:36 PM
Storage Box for Rear Bumper Craig D. Thompson Care and Feeding of Molded Fiberglass Trailers 12 09-03-2009 05:22 PM
Need bracket for 4" rear bumper Michael Pupeza Modifications, Alterations and Updates 4 05-29-2009 07:53 AM
Lady-Bug's new bumper paint job Gerry Modifications, Alterations and Updates 4 05-23-2007 11:49 AM
castors for rear bumper Legacy Posts Modifications, Alterations and Updates 5 01-17-2003 02:00 AM
