"xray" of Fiber Stream - Fiberglass RV
Old 08-21-2013, 02:41 PM   #1
Trailer: Fiber Stream
Maryland
I'm redoing the floor using a 3/4 ply overlay and made up this diagram showing the frame members. It s close but not perfectly accurate. I will post a revised version of this wIth the dimensions between members.
JD1994 is offline   Reply With Quote
Old 08-21-2013, 07:56 PM   #2
I KNOW I'm not going to be any help, I've only seen Fiber Steams from the outside (not the underside)... but I KNOW someone who KNOWS Fiber Steams inside and out.... Frederick, where are YOU?
Old 08-21-2013, 09:04 PM   #3
Seeing that he's pretty much got it right... The light gray lines are the frame's steel channel and the bluish lines are the axles.
Pics of the "New" Fiber Stream flyby Hi, I am.... 16 04-06-2012 06:49 PM
1976 El Macho 13fter "Casita type" $3800 Robin G Referrals: Molded Fiberglass Trailers 1 02-07-2010 08:46 AM
overcoming a "charm-ectomy", rotten floor & other issue Kelly G Problem Solving | Owners Helping Owners 5 05-22-2009 12:57 PM
