Old 09-28-2007, 11:12 PM   #1
Trailer: 1999 Burro 17 ft Widebody
Hi All,
I finally found a company that makes vented catalytic heaters for RV use! For us at least, this type of heater combines the best of both worlds – quiet, frugal DC power and gas consumption and low build up of humidity (since the heater is vented) and also, thermostat controlled. Unlike some older units, these heaters have interlocks built in to ensure they operate safely. The “Platinum Cat Heater” is offered by a small company in Olympia, Washington, called A&L Enterprises. They makes two sizes of the vented catalytic heaters. Their URL is http://ventedcatheater.com/index.html and phone number is (360) 446-5355; you can find more information. Since each heater is made to order you can probably find a configuration that works for your situation. Arnie the owner, was great at helping me determine the best set-up for their situation.
We’re using the larger 5200 BTU/hr model for our 17’ Burro (could barely squeeze it in under our counter). We set the thermostat at 60 degrees and can stay toasty all night. When I run the numbers on gas and power consumption (see the site for specifications), we ought to be able to run the heater for 80 hrs before we run our 20 gallon propane tank dry. The unit uses a very quiet fan that draws only 0.5 amps, and uses a piezo-electric igniter whenever the heater starts up.
I’m attaching a few photos of the final installation (left), cut-out wall and newly installed heater vent (upper middle), installed vent hose, gas line, 12 VDC and thermostat wires (upper right), lines and wires attached to heater prior to slipping the heater into place (lower middle) and thermostat location with heater below in background (lower right). All in all, it was pretty easy to install this myself.
We’re looking forward to extending our camping season now!
Steve & Dixie
S Sato is offline   Reply With Quote
Old 09-28-2007, 11:49 PM   #2
peterh's Avatar
I've been looking for something just like that! Thanks for the links!
Old 09-29-2007, 08:02 AM   #3
Trailer: Trillium 13 ft
Hi All :
The heater looks great (on their web-site),
BUT, I dont understand why the company does not add any info on PRICES !!
Maybe some one here has contacted them and could post price info..
Thanks
Dick Pack
Ham Radio : VE3HRP@ISP.COM
Dick Pack is offline   Reply With Quote
Old 09-29-2007, 10:01 AM   #4
Gina D.'s Avatar
West Coast
I had one of those in my 13.
The "low buildup of humidity" may be a bit misleading, a polite way of saying.. "You'll get humidity, but you may not need a wetsuit".
I found mine to be just as bad as any of the others out there. Might have been age, but...when I replaced with an unvented Olympian, I actually got LESS humidity.
It WAS smaller, and newer.. that may be where the contrast came in.
Old 09-29-2007, 12:47 PM   #5
Brian B-P's Avatar
We have had a few discussions of this heater design before, triggered by the one in Gina's old Burro. As I recall, the heater is not fully vented: the (catalytic) combustion occurs in a space open to the inside of the trailer, and much of the exhaust is taken outside by a vent, but it does not have the complete isolation of a regular direct-vent RV furnace.
It also gets its combustion air from inside the trailer; a traditional home furnace does the same, but a typical direct-vent RV furnace (such as my Boler's Suburban) takes the air from outside. The home furnace setup is clearly not ideal, and current building codes here require a fresh air intake ending right beside the furnace to ensure there is enough air supply. Taking air from inside makes a fresh air source - such as an open window - more important. Despite comments on the Platinum CAT website, it does require a fresh air source into the trailer.
I do not think that it would make sense for a completely vented furnace to use catalytic combustion. This design is a sort of compromise between the design of a radiant catalytic heater and the design of a conventional furnace. Like any compromise, it might deliver the right balance of features for the application.
Old 09-29-2007, 12:59 PM   #6
Brian B-P's Avatar
...BUT, I dont understand why the company does not add any info on PRICES !!
I assume that, like many small companies, A&L Enterprises probably does not want to maintain changing information - such as prices - on their website. It's a common problem for businesses without full-time computer staff.
Old 09-29-2007, 04:53 PM   #7
Hi All,
I should've mentioned that the heater, when I bought it earlier this year, ran between the price of a furnace and catalytic heater - about $450. Oddly, it's the same price for either size.
As Brian mentioned, since the heater draws air from inside the trailer (hence an open window or vent is needed), then vents the combustible gases (including moisture released from the propane) outside, in theory there ought to be less condensation build up than when we used a Mr. Heater last winter. I'll be able to confirm this, this winter.
Steve
Old 09-29-2007, 10:32 PM   #8
Trailer: 2003 Casita Spirit Deluxe 17 ft
I'm brand new to self contained camping so bear with me, but the combustion process of propane produces H2O? Is this removing Oxygen from the camper or just heating ambient humidity and causing condensation? I plan on camping a fair amount this winter and want to know what I'm up against with my Casita's factory heater...
Kyle is offline   Reply With Quote
Old 09-29-2007, 10:51 PM   #9
Bobbie Mayer's Avatar
Combustion produces CO2 and water (or CO and water if insufficient oxygen is present) and also, of course, produces heat. The reaction is
Propane + 5O2 ---> 3CO2 + 4H2O
It removes oxygen from the camper (if it is using air from the camper, which it appears that this is, but it would be possible to have air provided from the outside.) In this case, since a window has to be open, air is being drawn into the heater to fuel combustion. However, it sounds as if the combustion product gases are being vented outside in the vented heater. In an unvented heater, water would be produced and might cause condensation.
On the other hand, drawing in air from outside, on a winter night in the NW, may also result in condensation on the windows, since it will probably be higher humidity than the heated indoor air. I wonder why the design does NOT have air vented in as well as out?
Bobbie
PS, this is what happens when I read the forum instead of working on a chemistry exam I'm supposed to be writing.
Bobbie Mayer is online now   Reply With Quote
Old 09-29-2007, 11:48 PM   #10
Gina D.'s Avatar
West Coast
BENITA!!! Bobbie gets a beanie!
Old 09-30-2007, 12:34 AM   #11
HI All,
Someone pointed out to me that the Plat Cat Heater uses a nichrome wire to ignite it (not piezo electric, nor pilot light), thus the 5 amp draw for a couple minutes every time the heater starts up.
Steve
Old 09-30-2007, 04:02 AM   #12
Trailer: Boler 13 ft
HI All,
Steve
Not knowing anything about "Amp Draw" this worries me but maybe it shouldn't.
After going off last week and again Duo-therm not igniteing, I am starting to look for an alternative.
I am sure Brian or someone else will tell me is the running of the fan on the Duo-therm more costly on my singel battery then this 5 amp draw for a few minutes
Gerry the canoebuilder
Old 10-01-2007, 02:15 AM   #13
Paul Bostick's Avatar
Trailer: 2007 Casita 17 ft Spirit Deluxe
Casita Heater:
Kyle: You should not have a problem if you have a factory installed heater. They take the air they need for combustion from the outside and then vent the exhaust gases to the outside. One reason it is very important to keep those vents clear of mud daubers or other insects that might block the air intake or exhaust.
Paul Bostick is offline   Reply With Quote
Old 10-01-2007, 03:24 PM   #14
Brian B-P's Avatar
Thanks for the info! I wondered what all that power was for; a spark ignition system wouldn't use nearly that much or go for that long.
N... is the running of the fan on the Duo-therm more costly on my singel battery then this 5 amp draw for a few minutes
Since the regular furnace's fan is on whenever it is running, the energy consumption of that furnace will be much higher than the start-up energy plus the minimal exhaust fan consumption for the Platinum CAT.
My Suburban furnace draws enough that when its fan kicks on the lights in the Boler dim perceptibly... and stay dimmed as the fan runs. The voltage drop is presumably due to the primitive regulation of the converter not accommodating the current demand of the fan very well, but a similar effect occurs on battery power. At a low enough temperature the voltage drop is enough to keep my 12V fluorescent light from starting properly.
Vented cat heater Harry Young General Chat 28 04-30-2011 09:22 AM
Catalytic Heater william russell Classified Archives 1 07-30-2008 09:32 AM
Catalytic Heater Installation Nancy A. Problem Solving -- Owners Helping Owners 0 06-27-2008 11:54 AM
Catalytic Heater Question: Do they smell? peterh Problem Solving -- Owners Helping Owners 6 04-21-2008 09:10 PM
Portable catalytic heater Paula Bindrich Problem Solving -- Owners Helping Owners 19 10-13-2007 04:53 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
