Yet another jack questions--this time, Scamp 13 - Fiberglass RV
Old 05-30-2015, 05:08 PM   #1
Idaho
I acquired a pair of Atwood jacks for my scamp, and it looks like new Scamps come with jacks welded to the bumper.
Can anyone comment on the usability of Atwood Jacks http://www.amazon.com/Atwood-82301-S...abilizer+jacks and confirm or deny that Scamps now come with them welded to the rear bumper, at least on the S13 and S16?
I've been using scissor jacks for years, but they are a bugger to carry around. Based on the recommendations in other threads, I'm definitely going to look into one of the suggested types of jacks.
Cathy
CBinID is offline   Reply With Quote
Old 05-30-2015, 05:12 PM   #2
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Cathy, you can drill and bolt them on if you like. An easy do!
mszabo is online now   Reply With Quote
Old 05-31-2015, 02:52 PM   #3
M Scott's Avatar
Trailer: 13 ft 2005 Scamp Deluxe; 2002 Subaru V6 Outback
My 2005 Scamp came with welded rear jacks - a real pain to use because they have limited rising options. If I use them I usually have to add risers under the jacks.
I also use portable aluminum stack jacks in the front to ease the load on the tongue. If you get a set of 4, they stack easily and are lightweight.
M Scott is offline   Reply With Quote
Old 05-31-2015, 03:04 PM   #4
sokhapkin's Avatar
SW Florida
2014 Scamps come with the jacks bolted (not welded) to the rear bumper. To stabilize the trailer I usually lower tongue jack, extend stabilizer jacks and then level the trailer using tongue jack. Works fine on Scamp 16.
Sergey
www.callwithus.com
Old 05-31-2015, 04:57 PM   #5
My 92 Scamp has them bolted onto the rear bumper. I actually like them there as it is one less thing to have to bring along loose in the trailer or tug. They work fine for me. I do have a pack of leveling blocks that I use under the tires of the trailer but use the extras under the rear jacks if the ground is so unlevel the rear racks need extra height to land on.
Old 05-31-2015, 08:16 PM   #6
Bill Nolen's Avatar
Trailer: Had Scamp 13', want another small trailer.
My 1978 Scamp 13 has them bolted to the rear bumper.
One of the jacks I questions as to whether or not it will stay up when traveling. So I plan on using two straps to ensure that my jacks stay up!
Bill
Bill Nolen is offline   Reply With Quote
Old 05-31-2015, 08:31 PM   #7
I have them on the rear of my Uhaul and Casita and the front of our teardrop. Note they are "stabilizers", not intended to lift the trailer. I level side to side by blocking under a tire, or dig under one if on dirt, then level front to rear with the tongue jack and then set the stabilizers. I use the screw type stands on the front corners of the Uhaul and Casita.
Old 06-01-2015, 08:45 AM   #8
Bill
I have never had mine come down even though I don't always travel on paved roads but my friends have had theirs come down a couple of times so they strap them.
I think it may have to do with how tight the bolts are. For example if the bolts are over tightened on mine I can't get the jacks down for the life of me.
As has been mentioned they really are just stabilizers & not jacks. They are there to reduce the trailer movement when people are walking around in the trailer and to stop the tongue from going straight up in the air when two people get into the rear bed at night! Don't laugh have actually seen that happen a coupe of times now at trailer rallies.
Old 06-01-2015, 12:00 PM   #9
M Scott's Avatar
As I mentioned earlier, my rear jacks/stablizers that came with my Scamp are fairly useless on uneven ground. I use a BAL light trailer leveler that I absolutely love. It's available at RV stores and on Amazon. It's a bit heavy and awkward to pack, but I won't leave town without it.
Old 06-01-2015, 12:36 PM   #10
The BAl Light that you purchased is doing what it is designed to do. "Level" your trailer using the tires which is how one should level a trailer. They are a popular product here for doing that job just as levelling blocks .
As has been said the rear STABILIZERS on the Scamp are NOT designed or meant to be used to level a trailer or jack it up in anyway - so yes they will indeed do a real poor job if one tries to use them for that.
Old 06-02-2015, 09:56 AM   #11
I fought leveling my Scamp for over a year!! Finally, some camping friends of ours had some of the "LEGO" leveling pads they werent using. I got them for $15. VERY easy to back up on and have rarely needed more than 1 (apx 1" thick). These are the yellow ones with a solid top and not the kind where dirt/mud etc can go all the way through. I have a stack of 10 in a zip carrier bag. Very easy plus I can use them as a "ramp" to back up on if needed; place one back and/or front to set chocks on (they make a chock FOR locking on to these). I can also use the extras (instead of 2x6's) for placing under my stabilizers and front jack. This may sound funny...but they're bright yellow...hard to miss when you're packing up to leave camp. That CAN be an issue .
RV Leveling Blocks, 10 pack - North Canton Plastics D10-246 - Chocks & Levelers - Camping World
The BAL. I LOVE the concept and use my cordless drill to run my jack up and down which would be perfect for these. But for me, many of the campgrounds I stay in have concrete "patios". I park as close as I can to the patio as possible to keep from stepping down between the Scamp and patio (serious trip point). Therefore, the Bal would not work for me in those situations if needed on the door side.
I will reiterate something that's been repeated many times in these forums- DO NOT try to use the "Stabilizers" on the Scamps as JACKS. I use them only to stabilize and "tweak" my leveling bubble if necessary. Early on, I made "jacks" out of them and realize now how DANGEROUS that truly was! Dont do it!
Old 06-02-2015, 10:04 AM   #12
Bill
As to the jacks staying up while traveling. I've never is some 40,000+ miles had the stabilizers come down. I did have the inner part come out while traveling over a washboardy gravel road. Even that did not let them come down.
Old 06-02-2015, 10:13 AM   #13
Leveling and stabilizing (stoping most rocking)
The first thing I do is level the trailer side to side. I use a BAL leveler makes for a fairly precise leveling. However others have been successful using some sort of wheel blocks, "lego" or wood. Which ever you find convenient.
After it's level side to side, I unhitch. Since I'm using the BAL wheel leveler it's already well chocked. If you're using wood or plastic under the wheels make sure your well chocked before unhooking.
Once unhooked I lower the front with the tongue jack until the nose is about a 1/2 bubble low. Then I deploy the stabilizers, if the slope of the pad makes the stabilizers a bit short "legos" are used to make of the difference.
Once deployed I jack up the tongue to level. Light fridge, grad a camp chair, and a cold one. I'm reading for some serious camping (watching the plants grow).
ONE MORE THING. My 2006 came from the factory with the stabilizers bolted onto the bumper, not welded. I've replaced one.
Old 06-02-2015, 10:19 AM   #14
Yup...GOOD point I forgot to mention...ALWAYS "chock" before unhooking if you're not using something like the BAL. I've had some scary "shifts" in my rookie days! But one other precaution you have to watch especially with the lighter 13's... IF the tongue jack is on a slope AND you're not thoroughly chocked under BOTH wheels properly, I've seen the nose start to swing a bit...and that can be scary if you're not prepared.
One final precaution I've used over the years. I always unhitch from my "break-away" switch side. SHOULD something weird or freaky start to happen (and if I have time), I will grab the wire on the breakaway and stop the trailer! I HAVE tried that once and it worked. But the key is to not let the trailer get you in that dangerous situation. The only way to prevent it is proper chocking.
My wife still says... "Camping is not for the faint of heart!"
Jack-E-Up jack Victor Benz Modifications, Alterations and Updates 12 07-20-2017 04:12 PM
Yet another Scamp window A/C closet install. Allen Howell Modifications, Alterations and Updates 6 08-23-2014 05:39 PM
Tongue Jack Stand fits 2" jack FTTRV Commercial Posts and Products 7 06-20-2014 08:53 AM
And Yet Another Bought First Scamp! DonFromTexas Hi, I am.... 6 04-18-2012 05:26 PM
Yet another vent re-seal question: compact Junior Kent I Problem Solving | Owners Helping Owners 10 06-15-2009 04:18 PM
