Here is the kicker. This lamp which is a very good quality with a nice
weight to it has a 12volt wall wart with it. So if you wanted you could wire it into the 12 volt side of your RV.[/QUOTE]
Thank you, thank you, I’ll be there in the morning. I run everything possible on 12vdc. Remember that with LED polarity maters, if it first fails to light when you rewire it, it may be wired backward.
