Boiling in Zip Lock Bags - Page 2 - Fiberglass RV
Old 06-19-2012, 09:56 PM   #15
Mike Magee's Avatar
Trailer: Li'l Hauley
Yup, just add a little bacon grease to your skillet first. Good eatin'.
How to prepare Tofu
Step 2: grill some meat
Old 06-19-2012, 10:05 PM   #16
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
First of all, ziploc bags are made of Low density polyethylene, so the only thing they will release is ethylene, and then only if they are heated hotter than the temp of boiling water. Not a problem. I suspect the manufacturer just doesn't want the liability of saying it is safe to cook in them so they say it isn't.
Second, something you do once or twice a year on a camping trip is not something I'd worry about. If it had a slight risk, and you did it 365 days a year, then you worry.
Third, the smoke from your charcoal or wood fire is far more hazardous and so is the bacon.
IMHO... cook your eggs in the bags and don't sweat it.
One time I called the number on the side of some kind of food package to ask what would happen if I reused the plastic pan the food came in. The person I got admitted it was perfectly safe, they just say don't reuse it as some idiot will reuse it until it starts to fall apart, get burned, and sue. I suspect this is the same kind of reasoning.
Old 10-04-2012, 12:56 PM   #17
Normedina's Avatar
Trailer: Beaver
Originally Posted by bec
The other thing that it might be wise to consider avoiding is Teflon-cooking , not only does it not taste as good as when using pots or pans with a ceramic lining ( which is also non-stick - easy clean ), but it is advisable to not have a "canary "in the same area as cooking with teflon !
I made that mistake! My daughter had just given me 2 beautiful canaries, set the cage down on the kitchen table (by the big sliding window) to hear them singing while I made breakfast and I wasnt even done with the first egg when my grandkids noticed that one was already dead and the other one was twitching at the bottom of the cage. No one told me!
Normedina is offline   Reply With Quote
Old 10-13-2012, 03:54 PM   #18
Gina D.'s Avatar
West Coast USA
I have no microwave in my rig. I thaw solidly frozen meats (And other frozen items) by pouring boiling or near boiling water over it in a ziplock.
I let the bag float in the water for about 5 mins for an average sized serving and it thaws without cooking. I hate that with a microwave.
Passive aggressive thawing I call it :-)
Old 10-13-2012, 07:08 PM   #19
hotfishtacos's Avatar
Trailer: 2012 Escape 19' /2010 Honda Pilot 4WD TV
Escondido, California
What??!!
That was a good one!....
"No Generators"
hotfishtacos is offline   Reply With Quote
Old 10-13-2012, 07:54 PM   #20
Originally Posted by Bobbie Mayer View Post
First of all, ziploc bags are made of Low density polyethylene, so the only thing they will release is ethylene, and then only if they are heated hotter than the temp of boiling water. Not a problem. I suspect the manufacturer just doesn't want the liability of saying it is safe to cook in them so they say it isn't..
Actually according to Livestrong.org in a write up titled "What are the Dangers of Boiling Foods In Plastic Bags" they say "Ziplock brand bags have a softening point of 195 degrees, which means they would melt at boiling point, 212 degrees"
Under a section titled Chemical Leaching it reads "When plastic is boiled, the chemicals used to produce it can leach into the food being prepared due to a high temperature. Common chemicals in plastic include BPA and phthalates. Harvard Medical School says that high-fat foods are especially susceptible. NDSU adds that some plastic bags will leach toxic fumes from the ink, glue and recycled materials used in making them."
Old 10-14-2012, 12:14 PM   #21
Trailer: 1984 Scamp 13'
Maryland
I am getting away from teflon. It is really horrible stuff, no matter how you look at it. Cast iron is heavy, but a good, seasoned cast iron pan is more non-stick than any teflon pan I have ever used. And the teflon always wears off, anyway... it takes a long time for the cast iron to wear off of a cast iron pan!
Stainless steel is onay, but a bit of a pain to clean. Barkeeper's Friend does a good job, though. I HATE cooking in aluminum. I haven't found a way to keep my aluminum pots looking good.
-Jesse
Old 10-14-2012, 04:28 PM   #22
theresa p's Avatar
New Brunswick
hmmmm.....remember the words from the oncologist i work with!!!
heed his words....or seek his services.
your choice.
Old 10-21-2012, 09:15 PM   #23
Roger C H's Avatar
Smile Poaching
We use one of these in our microwave. Works great!
Microwave 2 Cup Egg Poacher - Nordic Ware
Hmm. Never used the shortening.
Bless the internet. Always has what you want:
http://www.slate.com/articles/life/f...west_food.html
Old 11-03-2012, 05:45 PM   #24
baron100's Avatar
Kansas
In a recent RV event, we migrated away from the popular omelet in a bag event to breakfast burritos. Everybody brought their fixings.
The omelet in the bag issue was getting as controversial as what tires should you put on your trailer.
Safe Travels!
Rob
http://casitaadventures.smugmug.com/
baron100 is offline   Reply With Quote
Do air bags help? Somey Towing, Hitching, Axles and Running Gear 11 03-11-2012 02:15 PM
Wag Bags Chester Taje General Chat 14 09-27-2009 12:33 PM
Zip Lock baggie fly control CarolnJim General Chat 7 08-17-2009 09:12 AM
Truck Air Bags with.......17' Casita Wiliam H Towing, Hitching, Axles and Running Gear 4 08-11-2009 05:05 PM
Boiling Battery!? JenPB Towing, Hitching, Axles and Running Gear 15 12-21-2008 03:00 PM
