Cooking a Roast on a portable BBQ... - Fiberglass RV
Go Back   Fiberglass RV > Rallies | Camping | Trip Reports > Camp Cooking, Food & Recipes
Old 09-17-2009, 04:01 PM   #1
So i'm importing more sailing tricks over here, and I've only been logged on for a day, but the more I read the more amazed I am at how transferable so many tricks are.
Here is how we cook a roast on a railmount BBQ while sailing. Of course you would be doing this in a park or what have you, but the methods would be about the same.
Step 1 - Find the right roast. This would be a roast that is long and skinny in shape. If you have a large-ish roast you may be able to cut it into chunks. The trick is that it has to fit into a tin loaf pan without touching the sides.
Step 2 - Slice an onion and put it in the bottom of the pan I also put in a bunch of carrot rounds or carrot sticks to hold the rost off the bottom of the pan. I refer to these as sacrificial veggies. They may be eaten or lost, either way the goal is to have the roast.
Step 3 - Place the roast on the veggies, and smother in your favourite spices. Pour a tin of tomatoes (with juice) and some white wine over it. or beer. If its a pork roast you can also use fruit juice. If none of these are available settle for water. If there is room slice up a potato or two and put it in the pan as well. Cover with tinfoil.
Step 4 - Put the pan in the BBQ and close the lid. Run it on the BBQ's lowest setting and leave the roast in as long as you would in your home oven. Remember that you are heating a small space in the camping BBQ, so it doesn't take much for it to overheat, keep an eye on the thermostat. (more on that later)
Step 5 - After the appropriate cooking time check with a meat thermometer. If its done, serve, if not, put it back in there and wait a bit.
Step 6 - Slice and serve while your guests try to figure out where you baked the roast.
By doing this on the BBQ, we avoid overheating the small space in our boat, and we find that the portable propane camping BBQ's ($20 at Ace hardware) give the same results as our fancy marine BBQ's ($500+ at the boatshow).
The trouble is that the cheap BBQ's don't always come with a thermostat, and that is critical if you are baking bread, roasts, or anything. This is where home depot comes into play. If you go to your local home depot, they will sell you a replacement BBQ thermostat for about $10.
All you have to do is drill 1 hole into the top of the BBQ, and the thermostat will mount on it. Some of the thermostats involve drilling 3 holes to mount them, but to me that is too labour intensive, so I opt for the single hole model. What is super-cool is that the thermostats outlive the BBQ's, so even after the BBQ is a rusted hulk from the spray of water on it when its cooking, your thermostat can be transferred to the next BBQ. Of course, while camping you likely won't be worried about that so much, but the idea is there.
Anyway, once you have the thermostat installed you need to calibrate it. To do this get an oven thermostat from your wife, put it inside the BBQ, and fire it up. Come back in 15 minutes and correlate the 2 thermostats. Use a high temperature paint to mark the BBQ right next to the thermostat every 50 degrees. Now you know what temps to aim for.
Being an RV-er you don't have to gimbal your cooker (unless you are super dedicated), but that isn't an impossible mod either. I won't go into details here though.
If you decide that you really want ot impress passers-by, you can use this same technique on a campfire. Instead of a BBQ, use one of those big enamelled roasting pans your Mom used to have. Do the drilling for the thermostat in its lid, and you have created an oven. Since campfires will burn the bottom of anything on the bottom of the pan no matter what you do, you need to get a steel wire pie trivet, and put it inside the "oven." The trivet wil lhold your bread/roast/cake/pie off the bottom and allow it to cook evenly in the fire. You just have to make sure the fire is kept small under the roaster, or you will quickly overheat it.
Chrs P is offline   Reply With Quote
Old 09-17-2009, 08:07 PM   #2
Trailer: Play Pac ('Egg Krate')
Fantastic idea. Thanks for posting it.
Plotting my next adventures...
Bonnie is offline   Reply With Quote
Old 09-18-2009, 08:59 AM   #3
No problem Bonnie.
We got our "Portable camping BBQ" at a local grocery store for cheap, and have created many great meals on it. I find that even on the lowest setting it wants to get really hot if the lid is left closed. I will often put a small steel dowel in to prop it open and let some heat escape.
Also - we will do steps 1-3 at anchor in the morning, then put the roast in the icebox until its time to start cooking dinner. Makes things go quick and easy at mealtime, with no prep stuff to clean up. I wouldn't want to be chopping veggies while underway anyhow. If you are lazy, tinned Potatoes can be used in this instead of real ones, but the rest of the veggies should be fresh (esp. the carrots) since they need to hold the roast off the bottom of the pan.
Old 09-18-2009, 09:48 AM   #4
CarolnJim's Avatar
Trailer: 2002 17 ft Casita Liberty Deluxe
Hi Chris
I tried your idea last night in our home BBQ.
I used two tin loaf pans.... onion, carrots, celery on the bottom... then country pork ribs on top, and added one medium potato to each pan.
For liquid, I used water and BBQ sauce in a measuring cup and stirred together - poured this over the two pans .. added salt and pepper and covered with aluminum foil with holes poked in the foil.
Pre-heated our BBQ to very hot .. put water in two small throwaway aluminum pans and set the two tin loaf pans on the water filled pans. Turned the fire underneath the pans to low and the two end burners to high and 2-1/2 hours later we had a delicious dinner... dinner complete in a pan. Yum!
(With the water pans, I didn't have to worry about burning the meal).
We have a George Foreman GV5 oven that I want to try while camping, but wouldn't need water pans.
(The GV5 oven might not be available but has been replaced with the GV6)
Thanks Chris for a good idea ...
CarolnJim is offline   Reply With Quote
Old 09-18-2009, 10:06 AM   #5
Hi Chris
No Problem - glad it worked for you.
Here is the type of BBQ we use... http://www.homehardware.ca/Products/index/...ropane_ttop_187
Old 09-18-2009, 06:28 PM   #6
Trailer: 2008 Oliver Legacy Elite
Thanks for the post, and for the detailed instructions. You'll find a lot of crossover from sailing to fiberglassrving.... (Except for the gimbals .. you won't be needing them at camp... .) We enjoy our little boat on wheels just as much as we love sailing in our thirty year plus boat.
Sherry
SherryNPaul is offline   Reply With Quote
Old 09-22-2009, 01:13 PM   #7
Sherry
Well if you ever find yourself thinking about RVing to Lake Simcoe, let me know and I'll set time aside to take you sailing!
portable toilet and portable shower Ruth G Plumbing | Systems and Fixtures 8 04-20-2012 12:36 PM
Cooking Marg Camp Cooking, Food & Recipes 1 05-16-2010 06:02 AM
pressure cooking Rarebird Camp Cooking, Food & Recipes 20 11-26-2008 10:05 AM
Solar Cooking John Perry Camp Cooking, Food & Recipes 3 08-21-2007 08:48 PM
cooking christineb General Chat 4 08-28-2006 05:34 PM
