Covers for sink, stove - Fiberglass RV
Old 05-28-2018, 01:11 PM   #1
Wisconsin
Hi, all.
I have a new (to me) 13' Scamp '04 Deluxe, and am hoping to find covers for both the sink and stove for when they're not in use. What do you all use?
The stove is a 2-burner gas (Suburban SD-2), and the sink is a small metal one, 15 1/4 x 13 outer, 13 1/4 x 11 inner.
Any ideas?
Thanks!
Kathy
Kgphd is offline   Reply With Quote
Old 05-28-2018, 01:59 PM   #2
John in Michigan's Avatar
Hi Kathy and welcome to the forum! For our Trillium 4500, we wanted a stove cover. A microwave sometimes sits on it when we have shore power. I first made a rough wood prototype for evaluation, and then much later I made this one:
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
John in Michigan is online now   Reply With Quote
Old 05-28-2018, 04:45 PM   #3
Wisconsin
Nice job! That's exactly the kind of thing I'm looking for. I assume it is "hollow" (rather than solid wood)?
Old 05-28-2018, 04:52 PM   #4
Kathy, yes its hollow. The sides are 1/2" solid poplar. The top is 1/2" birch plywood.
Old 05-28-2018, 05:03 PM   #5
I may wind up replacing the birch plywood with solid wood if it de-laminates. Also, this cover was finished with several coats of wipe on polyurethane varnish.
Old 05-28-2018, 05:12 PM   #6
Trillium 4500 stove cover
Here is the bottom of the cover.
Old 05-28-2018, 05:20 PM   #7
I made something similar to what John did for our Uhaul, using an off the shelf cutting board for the top. Later removed the stove and made that area storage so repurposed the same cutting board as a hinged lid. Another off the shelf cutting board covers the sink. If you need a custom sized cutting board there are a couple sellers on eBay that will cut to your specs a HDPE (plastic) cutting board. I got one with radius corners to fit over the stove in our Casita. They are available in various thickness.
Old 05-28-2018, 05:25 PM   #8
IllAnnoy
Hi, all.
Any ideas?
Thanks!
Kathy
I too have an '04 Scamp13D.
As you can see, the stove cover doubles as a counter extension when cooking, or as a table when the bed is made.
The sink cover is a standard plastic cutting board which was cut to fit the sink.
Here is my solution...
Old 05-29-2018, 09:28 AM   #9
Trailer: 2008 Casita 17 SD
Similar, but a little bit different. Not a nicely made piece of cabinet joinery like some others shown here, but more of a "quick and dirty" approach. Just a bamboo cutting board mounted on 4 short stainless steel legs made from 1" boat railing tubing. Four 1" rubber chair feet mounted to the bottom with stainless steel screws which go up into the bottom of the cutting board. If I want to use the stove, I just move it off to the side and set it on my full-time bed. Works good to extend valuable, (and almost non-existent,) counter space, and makes a good spot to put our coffee pot or toaster oven. The legs are spaced so as to cradle the four rounded corners of the stove top to keep it in place. Just be sure to pre-drill pilot holes for mounting the screws to keep from splitting the cutting board, and make sure that they aren't too long, so they won't "punch through" the top of the board.
Old 05-29-2018, 11:14 AM   #10
Trailer: Currently shopping
I used plastic cutting bords with pieces from a thinner cutting board hot glued to bottom for legs. the legs were plced to cradle the stove. the one for the sink the legs dropped below the sink rim to prevent sliding around.
J Ron is offline   Reply With Quote
Old 05-29-2018, 11:28 AM   #11
John in Santa Cruz's Avatar
Trailer: Escape 21
CA
if its Baltic Birch ply, it won't delam except under the /most/ extreme conditions.
Old 05-29-2018, 11:31 AM   #12
Here's the kitchen area in my Escape ( and photo of the underside of the sink cover to show how it is held in place. I've considered replacing the commercial range cover with one that doubles as a cutting board, but the one I have protects the vinyl wall from spatter.
Old 05-29-2018, 08:26 PM   #13
IllAnnoy
Dave;
Note the picture of the rear side of the stove cover, it has a reinforcement, two hooks , and two notches.
I simply open the drawer (deluxe only) as far as pictured, the notches fit on the drawer sides, the hooks hook behind the cabinet face and the partially opened drawer supports the stove cover....
Old 05-29-2018, 09:11 PM   #14
Trailer: Scamp 16, previously Scamp 13
None
Couple of cutting boards from Meijer (like Walmart) an some Spindle rail screwed/glued together. Works great.
LyleB is offline   Reply With Quote
For Sale: double sink/coleman oven-stove/stove vent/dometic fridge 3way jrocmagoo Parts: Buy | Sell | Trade 3 03-16-2013 03:38 PM
Stove/Sink Area Replacement georgia g Problem Solving | Owners Helping Owners 10 12-11-2008 10:25 AM
stove/sink combo JenPB Modifications, Alterations and Updates 6 10-18-2008 10:42 PM
13' kitchenette w/sink/stove/icebox/furnace and overhead cabinets Tim M Classified Archives 1 06-29-2008 07:42 PM
all in one sink & stove bonnie w General Chat 26 05-13-2007 09:38 PM
