Low-pressure outdoor stove - Fiberglass RV
Old 06-26-2018, 04:32 PM   #1
Trailer: Escape
My new Escape has a low-pressure quick-connect for outdoor cooking, so I'm looking for a camp stove that will work with that. I tried removing the pressure regulator from my old Century camp stove, but it seems that not all camp stoves work at rv-system pressure.
I prefer cooking outdoors when the weather is nice, but I don't want to keep bringing a separate tank when I should be able to plug into the trailer system.
Some folks connect the Coleman Road Trip to the quick-connect, but the Road Trip is a grill. What we want is a stove, just a simple 2-burner.
Al Bear is offline   Reply With Quote
Old 06-26-2018, 05:11 PM   #2
Trailer: BIGFOOT
I use the Camp Chef Ranger 2. Works great connected to my Bigfoot quick connect.
Mike Kelley is offline   Reply With Quote
Old 06-26-2018, 05:17 PM   #3
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
I have had the Camp Chef Ranger II for two years now, and just love it. Super easy to connect to low pressure. I just used a flared 90 to a pigtail with a AC male end.
This stove boils water fast, provides even heat across the bottom of the pan, and can simmer nicely at a very low flame, unlike any Coleman I have seen.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 06-27-2018, 09:50 AM   #4
Trailer: Escape
Thanks for the info, Mike and Jim. I just ordered one from Camp Chef.
Previously Camp Chef had told me by email that only their 14" series would work, but their 14" stoves are all bigger and heavier than the Ranger II.
Old 06-27-2018, 10:03 AM   #5
fofobraselio's Avatar
Trailer: 13' Boler
Hey al,
Visit your local gas/fireplace store if available. I have a bbq that only accepts small green 1lbs bottles and I wanted to hook up to the rv system. They hooked me up with a T fitting (one end to propane tank, one end to regulator into trailer, last end to hose that is compatible with bbq)
Chances are that if you need to connect gas lines or water lines, you will find the right fitting for your application.
Sent from my ONEPLUS A3000 using Fiberglass RV mobile app
fofobraselio is offline   Reply With Quote
Old 06-27-2018, 10:33 AM   #6
I think the Ranger series are relatively new. I came across them about 2 years ago and posted on the Escape Forum. At that point nobody had heard about them before. Since then we have cooked many a great deal on this stove outside
2017 Escape 5.0 TA
Old 06-27-2018, 10:39 AM   #7
Name: Larry and Gayle
This is what we use. We also bought the griddle surface which makes great pancakes.
https://www.amazon.com/Coleman-Roadt...eman+road+trip
Larry and Gayle D. is offline   Reply With Quote
Old 06-27-2018, 11:25 AM   #8
Trailer: Escape
Hi fofo,
I already have my hose fitting dialed in, with a fitting from the local lp gas supplier. Note that the approach you are using runs a high-pressure line to the regulator on you camp stove. That has the advantage of supporting any camp stove you might have. The advantage of a quick-connect on the rv 11-water-column-inch system (low-pressure system) is that the hose that you have to stash is shorter and burns off more quickly when you knock down. Plus, my feeling is that the less high-pressure lines and connections and hoses you have the better, in terms of safety.
Old 06-27-2018, 11:28 AM   #9
Trailer: 13' Boler
Absolutely, keep those high pressure lines as short as possible!
Hope your new stove works out for ya! Looks great
Old 06-27-2018, 12:28 PM   #10
Mike Magee's Avatar
Trailer: Li'l Hauley
You cook up deals? What about food?? . We know what you meant.
Did you hear about the butcher
who backed into the meat grinder?
He got a little behind in his orders....
Old 06-27-2018, 12:36 PM   #11
Meal, dammit!
Stupid swype typing, without editing.
Sent from my SM-N950W using Fiberglass RV mobile app
2017 Escape 5.0 TA
Low cold water pressure xbassman Plumbing | Systems and Fixtures 4 07-07-2016 02:17 PM
Outdoor Stove White Gas vs Propane? barryra General Chat 15 03-24-2013 11:17 AM
For Sale: double sink/coleman oven-stove/stove vent/dometic fridge 3way jrocmagoo Parts: Buy | Sell | Trade 3 03-16-2013 03:38 PM
Low Pressure Regulator jmacchi Problem Solving | Owners Helping Owners 5 01-23-2009 10:55 PM
Inside switch for outdoor light? Legacy Posts Modifications, Alterations and Updates 2 11-11-2002 09:00 AM
