Portable stoves - wood or gas? - Fiberglass RV
Old 04-11-2018, 04:17 AM   #1
Trailer: Newmar
I'm in two minds about my next outdoor purchase, a portable stove.
I've always heard great things about the Jetboil https://jetboil.johnsonoutdoors.com/...ystems/halfgen but it's pretty pricey.
I've also stumbled across various wood-burning stoves such as https://professionalcamping.com/quic...e-full-review/ but I'm unsure whether they would provide enough heat for all my cooking needs.
Would you recommend coughing up the extra cash for the gas stove or will the wood-burner be enough to cook my two meals a day?
camptheworld is offline   Reply With Quote
Old 04-11-2018, 06:21 PM   #2
Trailer: 77 Scamp 13
That quick stove is a fancy version of this $9 stove. https://www.amazon.com/Coghlans-9560...K0A3QWJT6&th=1
Same company has 72 packs of the heat tabs.
These stoves go back to around WW2 GI heat tab stoves one thing is the fumes are probably toxic, and they typically don't push a lot of heat. Good for some instant soup or instant coffee, or tea not so great for cooking a meal on unless it's heat water for freeze dried.
I carry the inexpensive one of those heat tab stoves in my day pack because the tabs can be used to start a fire in bad weather. Or for a quick cup of warm up. But as a main stove I have little interest in a stove with odd fuel that I probably won't find widely available. I would go with a single burner propane before a stove using an odd solid fuel.
Look into alcohol stoves a lot of models to pick from. Fuel widely available, car fuel deicer additive can be used comes down to it. As can pharmacy alcohol.
https://www.amazon.com/Solo-Alcohol-...ustomerReviews
Trangia is the granddaddy of the alcohol stove and stove kits. I might suggest drop the $15 to buy their most basic one, try it. If you like it get the larger kits, and you still have the small one as an extra burner or day pack stove.
https://www.amazon.com/Trangia-Spiri...3491830&sr=8-1
A whole assortment of Trangia stoves and kits.
https://www.amazon.com/Trangia/b/ref...se-bin=Trangia
On the single burner propane stove I mentioned earlier I would avoid the ones that go on top of a tank so the burner and pot are way up on top of a canister of propane. The ones with a burner and spider legs that attach with a short hose seem by far the safer choice in single burner propane.
Old 04-11-2018, 06:38 PM   #3
We tried a Coghlan's stove one year when fall camping in the BWCA. The temps were in the teens and it was windy .
We tried to make a pot of coffee , two hours later all we had was warm water . Summer time they work okay , winter time not so much.
I have been able to make coffee with an old fashioned Coleman stove in temps from 100 above to 30 below.
Old 04-11-2018, 07:44 PM   #4
Trailer: 2008 Casita 17 SD
Just my take on this topic, but as a kid, I remember growing up in the 50's with the old trusty Coleman pressurized white gas stoves, and you know what? That old technology can stay in the Smithsonian where it belongs. Besides having to carry a flimsy tin can of highly flammable gasoline around to fuel it, it always made the entire campsite reek of that gasoline smell, and everything I can ever remember that was made on it also reeked of gasoline. Yuk! No thanks.
Get yourself a good Propane stove. I have, and use, a couple of Camp Chef stoves, (a single burner and a two burner model,) and I have enjoyed them for many years. One of these stoves, and a light-weight composite Propane tank, and you're set.
If you want the flavor of a charcoal BBQ for camping, I also have the Weber "Go Anywhere," (actually, I have them in both Propane and charcoal burning models,) but there is no way that I would ever entertain using a gasoline stove for camping these days. YMMV
Old 04-11-2018, 07:56 PM   #5
I would never want to rely on woodburnning stoves of anykind. Wood at times is nearly impossible to acquire.
I've cooked over a wood fire, propane stove, coleman gas stove, butane or isotane stove. All have there pros and cons. Propane is mostly weight, butane is cold temps, (butane doesn't work below 32 F), isotane you have to deal with disposable canisters, coleman fuel (white gass) you've got liquid spillage to worry about. Alcohol stoves don't produce the heat the others do.
My preference is coleman fuel, an MSR Drangongly is my go to single burner stove. Next is the single burner is a coleman that uses colman fuel. I also have and 3 two burner stoves all coleman. 2 are porpane (one converted from white gas) one is very old 1940s white gas stove. All work good.
There's lots of options out there, I would evaluate them and choose according to you needs and wants.
FYI Mostly I use the two burner propane stove inside my trailer these days.
Old 04-11-2018, 10:00 PM   #6
Mike Magee's Avatar
Trailer: Li'l Hauley
I agree, the propane stove is about as handy as one can get. I bought one of those little alcohol stoves on a lark (it was cheap) and I have yet to use it... why lug around liquid fuel that can spill when a tidy sealed LP bottle is more convenient and makes a hotter flame.
To burn charcoal (or hold miscellaneous fuels), I am fond of this Portable Grills | Ecoque - A Greener Way To Grill which folds flat for travel. Just 9 charcoal briquettes will make a really hot fire for grilling in my 12" EcoQue. It's 2 years old and not a speck of rust yet after a number of uses, so they use good stainless steel. They're kind of hard to find, but Mountain Equipment sells them for $40.
Did you hear about the butcher
who backed into the meat grinder?
He got a little behind in his orders....
Old 04-11-2018, 10:02 PM   #7
In the summer time there are many areas of the country that will have a burn ban active. They would fine you if they caught you using a small wood stove for cooking. They also don't let you use charcoal during burn bans.
So if you only want to have one type of stove as your cooking equipment then go for one type or another of a gas/propane unit.
If you are not going to be cooking much of anything a jet boil will do. But if you want to cook some meals in a frying pan then get a propane or butane stove that is large enough to prevent accidental tip overs. Getting burned or having a mess to clean up is not much fun. I would suggest you look at one of the dual fuel cook-tops such as made by GasOne. They can use either small canisters of butane or be hooked to a 1lb propane cylinder or even a larger propane gas line. Then put back in the case and stowed away when not needed. You won't have any issue using it during a burn ban.
Old 04-12-2018, 04:33 AM   #8
Raz
Raz's Avatar
Vermont
I have a Primus Grasshopper propane stove I used in my backpacking days. I preferred propane over white gas. I also have used it during power outages before we switched to gas. Indoors it works quite well. Outside can be a different story. The problem with any of these stoves is wind can effect performance. Even a makeshift wind shield helps. There is a version of the Grasshopper sold on Amazon.
Old 04-12-2018, 07:08 AM   #9
I have ran the 2 burner coleman stove running on white gas for years. I flew that stove to Europe thinking no problem well no coleman fuel in Europe I don't know why. my solution I got an all fuel single burner stove by coleman that thing cooks.
easy to store and use lightweight also
bob
Old 04-12-2018, 09:45 AM   #10
Trailer: Parkliner 2014
For backpacking a while back, I checked into small wood stoves that would run on pine cones, twigs, etc., but decided gas was more reliable and I didn't have to worry about a wood fuel being dry. Certainly for outside trailer use I'd get gas, of the type you prefer. One thing to think of is other devices you might want that use the same fuel type.
FishingBob is offline   Reply With Quote
Old 04-12-2018, 10:27 AM   #11
good ideas
bob p/o took out our stove and sink I thought I would put it back in but we have worked out simpler things.
no sink we just use a little tub heat our water on our portable coleman stove.
I did finally relent and buy a portapottie it didn't have one of those we could have made it but it helps.
we use our little gas stove in the camper a lot when wx in the 20s hard to stand outside and run a stove in those temps. I couldn't believe I was able to fly our stoves to Europe by the way.
Old 04-12-2018, 10:39 AM   #12
Kai in Seattle's Avatar
We have a little wood/charcoal kettle BBQ and a one-burner butane stove. Both were fairly cheap (cheap is something that works that you find beside the road or on Craigslist free...) and the fuel is fairly easy to get. Sometimes we take both, usually we keep the little (blue!) butane stove tucked in a niche in Peanut with a couple cans of butane carefully packed nearby. So far no troubles with either.
We also bought a (blue) non-stick fry pan to use on the stove...and a blue silicon spatula. Oh, we be glamping, we be! (OK, Paul was merely the recipient of these blue camp items...I was the instigator of the color. Besides, they were on sale.) [Isn't everything you buy "on sale?"]
We use them outdoors, never inside Peanut.
Though we used to use Paul's childhood Coleman stove inside the GetAway Van. Looking back, having read about the possible 5-foot high flames if something goes awry, guess we were lucky. Our son sold it with the van.
Bye-bye, vintage Coleman.
Kai
Semper ubi sub ubi.
Old 04-12-2018, 10:41 AM   #13
glamping
so now I know what glamping is!!
bob
Old 04-12-2018, 11:54 AM   #14
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
We have the Cobb grill (kitchen in a bag) and love it! I suppose that we could use wood in it if caught without charcoal and I even have one of those tiny alcohol burners that we could use with it if we find ourselves really out of luck.
However, the stove/oven has been removed from our Bigfoot and replaced with a two burner electric portable hot plate that can be used inside or out. We usually cook outside and having all these options seems really flexible to me.
"Not all those who wander are lost." J.R.R. Tolkien
TheWanderers is offline   Reply With Quote
For Sale: old Trillium fridge, stoves and heater. chrispy35 Parts: Buy | Sell | Trade 23 06-21-2012 11:06 PM
propane stoves KevinWA Care and Feeding of Molded Fiberglass Trailers 3 05-18-2012 10:28 PM
Vintage camping equipment, lanterns, stoves, accessories... Lizbeth Hobbies & Passions 26 04-05-2011 02:49 PM
Difference between built in stoves and portable? melissab General Chat 21 08-22-2010 07:05 AM
Running Lamps/Stoves from LP Bottle Legacy Posts Problem Solving | Owners Helping Owners 13 03-19-2003 11:16 AM
