Using a microwave?! = NOT real... - Page 3 - Fiberglass RV
Old 07-26-2011, 09:24 PM   #29
Trailer: 1986 Bigfoot 17 ft ('The Sea Glass')
I ended up taking the Microwave out of the Bigfoot and putting in a toaster oven after it blew a fuse (I guess back in '86 when it was built they didn't need such strong electrical circuits). I don't miss it that much, as it was heavy and took up a lot of counter space, and the toaster oven only takes a little longer.
Our camping trips usually involve a group of friends, and one of the joys of camping with friends is visiting with them while we cook, so I tend to use the coleman stove outside on the table. One thing I picked up at a rummage sale that has come in really handy for big gatherings (where everyone kind of pitches in with a potluck item) is a dutch oven (a big cast iron pot with a cover. It usually sits over the coals cooking up something anytime a fire is allowed. Here are a couple of favorite recipes (2 for breakfast, the 2 for dinner):
One Pot Tortilla Breakfast
Ingredients
  • 2 tsp. vegetable oil
  • 2 medium green, red, and/or yellow peppers thin sliced
  • 1 small red onion thin sliced
  • 1 (1.25 oz.) package taco seasoning mix
  • 1 can evaporated milk
  • 6 large eggs, lightly beaten
  • 12 (6 in.) fajita- size flour tortillas, warmed
  • 1 jar of salsa
  • 1 tub of sour cream
  • 1 lb. shredded cheddar cheese
Heat oil in Dutch oven. Add pepper, onion and seasoning mix, stir well. Cook well for 3 to 5 minutes or until vegetables are crisp- tender. Transfer to bowl, cover.
Combine evaporated milk and eggs in bowl. Pour into oven and scramble until soft curds form. Move eggs to center of oven. Arrange vegetables around eggs. Sprinkle cheese over eggs and vegetables.
Serve with tortillas. Garnish as desired.
Mexican Casserole
Ingredients
  • 1 lb breakfast sausage hot or regular
  • 1 lb ground beef
  • 1 medium onion chopped well
  • 2 eggs
  • 1 can Rotel diced tomatoes drained well
  • bread crumbs as needed
Mix well adding bread crumbs to produce a dense meatloaf. Place in a #10 Dutch oven that has been sprayed well with a non stick spray. Cover and cook for about 30 min or until almost done.
While that is cooking, mix 2 boxes of cornbread mix according to the instructions given and add the following:
  • 1 small onion finely chopped
  • 2 medium jalapenos finely chopped
  • 1 can of creamed corn
Mix well.
Remove meat from oven and carefully drain off any liquid. Pour cornbread mixture over the top of the meat and return to oven for approximately 20 min. Watch this carefully. Check for doneness with a toothpick.
Barbecue Ribs
  • 1/2 Rack of spare ribs
  • Salt and Pepper ribs according to taste
  • Your favorite barbecue sauce
Braise in a hot Dutch Oven for 30 to 40 minutes at approximately 450 degrees. Cover lid completely with coals, same with bottom. Check for browning, turn if necessary. Separate ribs and cover with your favorite barbecue sauce. Bake for approx. 2 hours with 14 coals on top and bottom.
Bratwurst Stroganoff
Ingredients
  • 2 lbs stadium style bratwurst
  • 1 lb package of Portabella mushrooms, sliced thin
  • 1 large, flat Vidalia onion sliced very thin
  • 1 quart sour cream
  • 1 quart white wine
  • 1 to 2 tablespoons of flour
  • 2 tablespoons of high heat oil (peanut or olive)
  • 1/2 tablespoon garlic powder
  • salt and pepper to taste
  • 2 large packages (24 oz to 32 oz total weight) extra wide egg noodles
Set sufficient water to boil in accordance with the package directions of the noodles. A large pinch of course salt may be added to speed boiling and help flavor the noodles. Heat a large skillet (12 to 14 inch) and add the oil. Immediately place the brats into the oil and begin to move them around to completely brown them. This should take about ten minutes. Remove the brats from the pan and allow to rest at least five minutes. Check the water and when appropriate add the noodles. After the brats have rested, slice them into 1/2 inch pieces and set aside for later use. Add the onions to the skillet and reduce the heat slightly to a medium high. Allow the onions to just begin to turn clear then add the mushrooms. Raise the heat slightly closer to high. The vegetables should begin to absorb the drippings from the pan. When this happens return the sliced brats to the pan and allow them to cook for about 5 minutes while continually stirring. If the pan appears to be dry additional cooking oil may be added a half tablespoon at a time. Add no more than one additional full tablespoon. Sprinkle one half the flour over the contents of the pan and add the garlic. Stir to combine well and to absorb the flour. Add the sour cream and combine well. Add the wine a little at a time to achieve a consistency about like a sausage gravy or a bit thinner. This should take about half of the wine. When the noodles are finished drain them well, add them to the sauce and combine well. Check the sauce. If it is too thick add a little more wine and combine. If too thin (doesn't coat the noodles) sprinkle a little of the remaining flour over the dish and combine well. Do not use more flour than what was left over from the original recipe measure because too much raw flour will ruin the dish.
Toni M T is offline   Reply With Quote
Old 07-26-2011, 09:30 PM   #30
One campfire meal I have eaten (but didn't cook) was at a "Cowboy" gathering where the coffee was put into clean socks and boiled in a big pot of water over the fire (it made a lot-they served it with a dipper), and the supper steaks were put on long handled, all metal BBQ forks and fried in a big pot of oil in the same pot over the nighttime fire. Although the steaks were really good, I imagine eating deep fried steak
like that would not be too healthy on a regular basis!
Old 07-26-2011, 09:30 PM   #31
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Hi, Toni
Now, THAT'S what I call Camp Cookin'!
I love my dutch oven- I even bought an itty-bitty one for when I camp alone
I'll be trying your recipes!
Francesca
Old 07-27-2011, 04:40 AM   #32
honda03842's Avatar
Name: Norm and Ginny
Western Dinner Theater - Pitchfork Steaks
In Medora, ND there's a 3000 person theater built in the side of a mesa, you go down 7 stories in an escalator to get to the show.
Before the show there is a buffet/barbaque. They place about 10 steaks on the tines of each pitch fork and cook them in these human size pots of peanut oil. It seemed to take a fraction of a minute to cook them. The steaks were great as was the stage show - actually horses on the huge stage.
Norm
microwave
Real Name Kevin K General Chat 50 10-25-2009 10:13 PM
Real spider Bill MacDermod Jokes, Stories & Tall Tales 5 01-31-2009 10:28 PM
A Real Neat New One! Ken James General Chat 29 04-29-2007 10:59 AM
One real and one what if question??? Linda&Dale Problem Solving | Owners Helping Owners 11 11-19-2006 10:45 AM
a real funny Dan Quinn Jokes, Stories & Tall Tales 2 05-11-2006 09:42 AM
