Can't light the friggin' refer? - Fiberglass RV
Go Back   Fiberglass RV > Fiberglass RV Community Forums > General Chat > Jokes, Stories & Tall Tales
Click Here to Login
Old 08-15-2012, 09:10 AM   #1
Jim Bennett's Avatar
Just a fun observation of one example the different terminologies used across the continent.
Around here the refrigerator gets shortened to 'fridge'. I see others using 'frig' which to me is more commonly used as a milder version of the F-bomb. Others use 'refer', which to me is one of those wacky tobacky things (or so I've been told ).
I guess I just entertain easily, carry on.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 08-15-2012, 01:16 PM   #2
Administrator
Mary F's Avatar
Just be sure the gas is ON. You'll never get it lit if it's switched to AC or DC. Believe me, I know ...
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 08-15-2012, 01:51 PM   #3
Trailer: 13' 2007 Scamp without bathroom
Heehee
realgranola is offline   Reply With Quote
Old 08-15-2012, 02:03 PM   #4
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Considering the finicky temperament of 3-ways, I can understand how fridge might turn into frig under one's breath. As to "refer," when I first saw this spelling in reference to rv refrigerators, I thought it was a mispelling of "reefer," a large, refrigerated container as in reefer car (railroad), and reefer trailer (road). The same phonetically but one missing the double-E. Maybe the lack of utility of the 3-ways doesn't warrant two Es? The usual spelling for the cannabis cigarette is also reefer rather than refer. Perhaps the recreational vehicle and the recreational chemical didn't mix thus the removal of the second E. One of the very good reasons not to name everything on the planet by the same name. The reintroduction of an old slang word from the Viet Nam War era may be over-dew.
jack
Old 08-15-2012, 02:32 PM   #5
Trailer: Helite
I-cA-BoxA
Italian fro Fridg
Art VanDelay is offline   Reply With Quote
Old 08-15-2012, 02:52 PM   #6
Gee Mary. I have never done anything like that....yeah, right.
jack
I had the same thought about a refrigerated container too Jack, and wondered if there was a parallel. I knew reefer was misspelled, but did not want to change the spelling for my post.
2017 Escape 5.0 TA
Old 08-15-2012, 03:41 PM   #7
rabbit's Avatar
Delaware
. . . and how did the (soft G) "DG" get expressed in "fridge" when it's understood in frigid? Most folks think it has something to do with the brand name Frigidaire. Others don't care. If you do care, here's a link:
BBC - mbradio4 Word of Mouth - refrigerator
Old 08-16-2012, 08:11 AM   #8
fusedlight's Avatar
Trailer: 16' 1998 Scamp
One thing I've done that's let me successfully (well, two or three times) light the 2-way is to hold the right-hand button down for a good minute AFTER I can see the little flame in the sight-hole on the left. I figure that what you're doing with that right-hand button is over-riding the "I'm going to turn off the gas if I don't feel heat" sensor gizmo. Unless that sensor is heated up the gas "should" turn off. Holding the button down makes sure that sensor is warm enough to let the gas flow. I'm surmising this based on the lighting sequence for my home gas furnace.
fusedlight is offline   Reply With Quote
Old 08-16-2012, 08:56 AM   #9
Trailer:
In just these circumstances, I am a great fan of holding the button down very firmly, so that the button knows you aren't going to give in easily and let go. A mind over matter thing.
Old 08-16-2012, 09:13 AM   #10
fusedlight's Avatar
Absolutely! It's the same technique I use with computers. You talk sternly to the box whilst performing some operation.
Old 08-16-2012, 12:07 PM   #11
dylanear's Avatar
Trailer: 2001 Scamp 13'
I don't think your supposed to do it this way, but I've found a "jet" lighter pointed through the observation hole has worked well for me.
dylanear is offline   Reply With Quote
Old 08-16-2012, 02:00 PM   #12
When I worked as a Teamster in the 1960's ,a box car or trailer load of refrigerators was always referred to as a load of "refers" even by the guys in their 60's . When they were multiple boxcars stacked 2 high with refrigerators and you had to unload them by yourself ,by hand (No help No forklift) it was referred to as "refer madness" .
Old 08-16-2012, 02:52 PM   #13
rabbit's Avatar
Delaware
And there's that fine old anti-drug film from the 30s called "Reefer Madness" and later adapted as a musical. Possibly some x-pollination there also.
jack
Old 08-16-2012, 03:30 PM   #14
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
I think people put a D in the fridge just so it wouldn't look like, um, that other activity.
Old 08-16-2012, 07:20 PM   #15
Trailer: 2010 Scamp 16
If it works and keeps the beer cold you can call it anything you want. But when it won't light or doesn't run you can't post what the thing gets called then.
Old 08-16-2012, 09:54 PM   #16
No friging way!
True Dat, RogerDat.
2017 Escape 5.0 TA
Old 09-21-2012, 05:10 PM   #17
Steve Hammel's Avatar
Trailer: Trillium 4500
It works best if you light your refer before you light your reefer. Otherwise you get lit and tend to stare at all the flames for a great deal of time while holding the button and the refer never seems to function properly. I've known people to just sit and stare for 10 minutes while holding that friggin button.
Old 09-21-2012, 07:56 PM   #18
There are also those occasions when you may become concerned about whether or not you have pressed it far enough or hard enough, and a few "gentle taps" with a 15 pound sledge seem to be called for.......
Old 10-25-2012, 02:19 PM   #19
RGill's Avatar
Trailer: Yellow Winnebago
Kentucky
I just wasted a nickel bag trying that!
RGill is offline   Reply With Quote
light
Adding a furnace, and a refer Kent I Modifications, Alterations and Updates 2 05-13-2011 03:11 PM
Old refer not working? John Perry Problem Solving | Owners Helping Owners 2 07-30-2006 12:28 PM
Condensation in refer? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 07-28-2003 04:02 AM
Where does the refer drain? General Chat 0 01-01-1970 12:00 AM
