Funny Camping Jokes...Add your own - Page 2 - Fiberglass RV
Old 02-03-2017, 12:41 PM   #21
cpaharley2008's Avatar
I have several of some of these, very funny....
Jim
Never in doubt, often wrong
Old 02-03-2017, 12:49 PM   #22
Carl Pa's Avatar
I concur...
Carl Pa is offline   Reply With Quote
Old 02-03-2017, 12:51 PM   #23
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Looking forward to warm weather so I can go camping.
The groundhog saw his shadow?
6 more weeks of winter??
FAKE NEWS!
NOT MY GROUNDHOG!
Old 02-03-2017, 01:30 PM   #24
jerrybob's Avatar
Trailer: casita
Two men went bear hunting. While one stayed in the cabin, the other went out looking for a bear. He soon found a huge bear, shot at it but only wounded it.
The enraged bear charged toward him, he dropped his rifle and started running for the cabin as fast as he could. He ran pretty fast but the bear was just a little faster and gained on him with every step. Just as he reached the open cabin door, he tripped and fell flat.
Too close behind to stop, the bear tripped over him and went rolling into the cabin.
The man jumped up, closed the cabin door and yelled to his friend inside, "You skin this one while I go and get another!"
jerrybob is offline   Reply With Quote
Old 02-03-2017, 02:25 PM   #25
Trailer: Boler 13 ft
Originally Posted by kevin57 View Post
When restoring a trailer it's good to know the real uses of some of our tools......
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands, so it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabilizer which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar calluses from fingers in about the time it takes you to say, "Yeeou sh#*...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touchup jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy-duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub that you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for over the last 45 minutes.
TABLE SAW: A large, stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an rv to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an rv upward off of a trapped hydraulic jack handle.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
HOSE CUTTER: A tool used to make hoses too short.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes, thereby ending any possible future use.
RADIAL ARM SAW: A large, stationary power saw primarily used by most shops to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over-tightened 30 years ago by someone at Ford, and instantly rounds off their heads. Also used to quickly snap off lug nuts .
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
PNEUMATIC RIVET SQUEEZER: Tool designed to accurately remove 1/4 moon shaped pieces of your left index finger.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs.
Kevin you forgot
EXTENSION CORDS: A lenght on wire you can practice tieing and untieing knots
Old 02-03-2017, 03:46 PM   #26
kevin57's Avatar
Trailer: Miti-Lite
Originally Posted by Gerry View Post
Kevin you forgot
Thanks for catching that over site. That's a good one.
"Always look on the Lite side of life" - Eric Idle
kevin57 is offline   Reply With Quote
Old 03-14-2017, 06:45 PM   #27
Trailer: In the market
New Mexico
One of the late night talk show hosts, I think it was Jimmy Fallon, said: "Thank goodness for GPS. I don't know where I'd be without it!"
Groan.
George in New Mex is offline   Reply With Quote
Personal funny faces of your self Chester Taje Jokes, Stories & Tall Tales 8 11-16-2005 04:41 PM
Canadian Jokes Legacy Posts Jokes, Stories & Tall Tales 4 12-09-2002 10:29 AM
Tasteful jokes Legacy Posts Jokes, Stories & Tall Tales 14 11-26-2002 08:37 AM
Elephant jokes Legacy Posts Jokes, Stories & Tall Tales 16 10-17-2002 04:00 PM
Jokes from Augie B Legacy Posts Jokes, Stories & Tall Tales 3 09-24-2002 07:29 PM
